I’m using Arch Linux, after an update for the entire system the last month,
I lost the ability to do simulation with gazebo, I remember that the problem was that ogre was not able to load resource file for iris model, after an extensive debug, we discovered that ogre has lost the ability to load PNG files.
We have comments the lines that corresponded to the png photo models filed for Iris. Since then every thing was
fine for single vehicle simulation even with Iris model.
Today I have tried to do multi vehicle simulation with Gazebo. I’m using ROS Melodic, I followed the instruction described in the website as usual, I did not realize any modifications on the launch files executed by ROS.
I receive now the following error message after launching mavros:
Using the following command:
roslaunch multi_uav_mavros_sitl.launch debug:=true verbose:=true
I got the following error after a while:
[Err] [InsertModelWidget.cc:433] Missing model.config for model “Firmware/Tools/sitl_gazebo/cmake”
[Err] [InsertModelWidget.cc:433] Missing model.config for model “Firmware/Tools/sitl_gazebo/external”
[Err] [InsertModelWidget.cc:433] Missing model.config for model “Firmware/Tools/sitl_gazebo/include”
[Err] [InsertModelWidget.cc:433] Missing model.config for model “Firmware/Tools/sitl_gazebo/models”
[Err] [InsertModelWidget.cc:433] Missing model.config for model “Firmware/Tools/sitl_gazebo/msgs”
[Err] [InsertModelWidget.cc:433] Missing model.config for model “Firmware/Tools/sitl_gazebo/scripts”
[Err] [InsertModelWidget.cc:433] Missing model.config for model “Firmware/Tools/sitl_gazebo/src”
[Err] [InsertModelWidget.cc:433] Missing model.config for model “Firmware/Tools/sitl_gazebo/worlds”
[Err] [RenderEngine.cc:543] EXCEPTION: Unable to load Ogre Resources.
Make sure theresources path in the world file is set correctly.
terminate called after throwing an instance of ‘gazebo::common::Exception’
/opt/ros/melodic/lib/gazebo_ros/gzclient: line 42: 30633 Aborted (core dumped) GAZEBO_MASTER_URI="$desired_master_uri" GAZEBO_MODEL_DATABASE_URI="$desired_model_database_uri" gzclient $final
I have no problem with single vehicle simulation now,
Do you have any idea about this problem?? I had ogre and gazebo updated in the last update of arch linux,
By the way, I have tried to start another vehicle than iris, it seemed that there is no xacro files for these vehicles,
Should I create one for each vehicles??
That’s odd. Could you make a pull request with your changes that you had to do to get this running with latest OGRE again, or send me a patch. That way I would understand what you have done and could probably reproduce this issue.
I’m still stuck at the single vehicle simulation which doesn’t work anymore.
Gazebo multi-robot simulator, version 9.4.1
Copyright (C) 2012 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.0.123
[Err] [Plugin.hh:180] Failed to load plugin /home/julianoes/src/Firmware-master/build/posix_sitl_default/build_gazebo/libgazebo_multirotor_base_plugin.so: libvtkInteractionStyle.so.1: cannot open shared object file: No such file or directory
[Err] [Plugin.hh:180] Failed to load plugin /home/julianoes/src/Firmware-master/build/posix_sitl_default/build_gazebo/libgazebo_motor_model.so: libvtkInteractionStyle.so.1: cannot open shared object file: No such file or directory
[Err] [Plugin.hh:180] Failed to load plugin /home/julianoes/src/Firmware-master/build/posix_sitl_default/build_gazebo/libgazebo_gps_plugin.so: libvtkInteractionStyle.so.1: cannot open shared object file: No such file or directory
[Err] [Plugin.hh:180] Failed to load plugin /home/julianoes/src/Firmware-master/build/posix_sitl_default/build_gazebo/libgazebo_mavlink_interface.so: libvtkInteractionStyle.so.1: cannot open shared object file: No such file or directory
[Err] [Plugin.hh:180] Failed to load plugin /home/julianoes/src/Firmware-master/build/posix_sitl_default/build_gazebo/libgazebo_imu_plugin.so: libvtkInteractionStyle.so.1: cannot open shared object file: No such file or directory
[Wrn] [GuiIface.cc:120] Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt.
You must not let any exception whatsoever propagate through Qt code.
If that is not possible, in Qt 5 you must at least reimplement
QCoreApplication::notify() and catch all exceptions there.
Interesting, I think this problem is related to Gazebo rather than ogre.
I’m using gazebo 9.3.0 I do not know if I am going to have this problem if I do an upgrade for gazebo.
I do not know the version of your firmware, I have the version 1.8.0-rc0
I used ldd to see if there is any dependency for VTK library, I discovered that it is not installed on my system at all.
Could you please post the output of ldd on the libgazebo_*.so ??
[Err] [main.cc:34] Ogre Error:ItemIdentityException: Can not find codec for 'png' image format.
Supported formats are: dds ktx pkm. in Codec::getCodec at /build/ogre/src/ogre-1.11.1/OgreMain/src/OgreCodec.cpp (line 66)
In fact, you need to download the sources from the AUR, and apply the patch manually to avoid this error
Otherwise it is going to take a lot of time waiting for the maintainer to apply this patch to the source
Ok, I was able to install gazebo with the OGRE-1.9 change according to https://aur.archlinux.org/packages/gazebo/#comment-667054, and I made sure sitl_gazebo is using the same OGRE headers and libraries manually. However now I get:
In file included from /usr/include/gazebo-9/gazebo/rendering/ogre_gazebo.h:61,
from /usr/include/gazebo-9/gazebo/rendering/Camera.hh:46,
from /home/julianoes/src/Firmware-master/Tools/sitl_gazebo/include/gazebo_geotagged_images_plugin.h:25,
from /home/julianoes/src/Firmware-master/Tools/sitl_gazebo/src/gazebo_geotagged_images_plugin.cpp:18:
/opt/OGRE-1.9/include/OGRE/Terrain/OgreTerrainPaging.h:33:10: fatal error: OgrePagedWorldSection.h: No such file or directory
#include "OgrePagedWorldSection.h"
compilation terminated.
I’m having a hard time with this patch. I’m not familiar with PKGBUILD and I somehow can’t get the patch applied correctly. I’m going to have to wait until the maintainer pulls in the patch, I think.
I discovered that, spawn model files in gazebo_ros package uses python 2 .7 instead of 3.7 when importing library such as urllib. So, after a modification to the Python script of this package, I found myself in deeper non understood error
[INFO] [1540394622.726954, 0.068000]: Calling service /gazebo/spawn_urdf_model
File “/opt/ros/melodic/lib/gazebo_ros/spawn_model”, line 233, in
exit_code = sm.run()
File “/opt/ros/melodic/lib/gazebo_ros/spawn_model”, line 179, in run
self.args.gazebo_namespace)
File “/opt/ros/melodic/lib/python3.7/site-packages/gazebo_ros/gazebo_interface.py”, line 32, in spawn_urdf_model_client
resp = spawn_urdf_model(model_name, model_xml, robot_namespace, initial_pose, reference_frame)
File “/opt/ros/melodic/lib/python3.7/site-packages/rospy/impl/tcpros_service.py”, line 439, in call
return self.call(*args, **kwds)
File “/opt/ros/melodic/lib/python3.7/site-packages/rospy/impl/tcpros_service.py”, line 516, in call
transport.send_message(request, self.seq)
File “/opt/ros/melodic/lib/python3.7/site-packages/rospy/impl/tcpros_base.py”, line 668, in send_message
serialize_message(self.write_buff, seq, msg)
File “/opt/ros/melodic/lib/python3.7/site-packages/rospy/msg.py”, line 152, in serialize_message
msg.serialize(b)
File “/opt/ros/melodic/lib/python3.7/site-packages/gazebo_msgs/srv/_SpawnModel.py”, line 103, in serialize
_x = _x.encode(‘utf-8’)
AttributeError: ‘bytes’ object has no attribute ‘encode’
[INFO] [1540394622.882709, 0.220000]: Calling service /gazebo/spawn_urdf_model
If anyone has an idea about how does this package work, feel free to contact me
I executed the commands separately from roslaunch, I obtained the same error. The generated code should works out of the box for Python 3.
I was not able to understand the result error, especially that _x is a string and should have by default the encode() function.
/opt/ros/melodic/lib/gazebo_ros/spawn_model -sdf -file /meta/Firmware/Tools/sitl_gazebo/models/iris/iris.sdf -model iris -x 0 -y 0 -z 0 -R 0 -P 0 -Y 0
Unable to register with master node [http://localhost:11311]: master may not be running yet. Will keep trying.
[INFO] [1540485626.864298, 0.000000]: Loading model XML from file /meta/Firmware/Tools/sitl_gazebo/models/iris/iris.sdf
[INFO] [1540485626.873756, 0.000000]: Waiting for service /gazebo/spawn_sdf_model
[INFO] [1540485629.896535, 0.020000]: Calling service /gazebo/spawn_sdf_model
File “/opt/ros/melodic/lib/gazebo_ros/spawn_model”, line 183, in run
File “/opt/ros/melodic/lib/python3.7/site-packages/gazebo_ros/gazebo_interface.py”, line 20, in spawn_sdf_model_client
resp = spawn_sdf_model(model_name, model_xml, robot_namespace, initial_pose, reference_frame)
msg.serialize(b)
