I am creating this post as a VERY IMPORTANT ISSUE, need to be resolved .
I work on multi vehicle simulation, which use: gazebo, PX4, ROS
Everything worked fine until the version of kinetics of ROS,
Once I have done an upgrade and moved to melodic nothing is working anymore.
Apparently, several issues arise considering the problem of moving from Python 2 to 3 in melodic
I tried to move part of the scripts from python 2 to 3. However, once I resolve a bug a new bug is generated.
After several weeks of working on this issue, I am posting on this forum trying to have a contact with the maintainers of multi vehicle simulation that are around and ready to help to resolve this issue.
I don’t work with ROS myself, so I can’t really help, sorry.
However, I suggest to use the versions supported by PX4, usually that’s based on Ubuntu, and whatever ROS comes with it, and mostly still on Python2 I believe. Sorry I don’t have a better answer.
If you have any contact with anyone working on Multi vehicle simulation it will be appreciated.
Also the actual problem is more related to parameters of Spawn_model passed by launch files in the Firmware.
I will also try to resolve the problem, I will announce the solution once I found it.
In fact, I believe that software should be maintained and validated for every new version of dependency. After 2020, Python 2 is going to die, and every body will be obliged to move to Python 3 which mean ROS melodic.
I think it is from our interest to move to new version as soon as possible, A lot of tests should be done before being sure the the software is valid for the new version of ROS.
I do not know if this issue should be listed on the Todo list for PX4 team. I prefer to report it here to reach the entire community of users and developers.
I had to use 2to3.7 tool to move the some ros libraries from python 2 to 3.
I started by updating gazebo_ros then rospy then rosgraph
The last un debugged error is the following:
[rospy.core][INFO] 2018-11-09 15:29:52,260: signal_shutdown [atexit]
[rospy.impl.masterslave][INFO] 2018-11-09 15:29:52,262: atexit
[rospy.client][INFO] 2018-11-09 15:34:01,336: init_node, name[/iris_1_spawn], pid[19349]
[xmlrpc][INFO] 2018-11-09 15:34:01,336: XML-RPC server binding to 0.0.0.0:0
[xmlrpc][INFO] 2018-11-09 15:34:01,337: Started XML-RPC server [http://linux-4-102:34327/]
[rospy.init][INFO] 2018-11-09 15:34:01,337: ROS Slave URI: [http://linux-4-102:34327/]
[rospy.impl.masterslave][INFO] 2018-11-09 15:34:01,337: _ready: http://linux-4-102:34327/
[rospy.registration][INFO] 2018-11-09 15:34:01,338: Registering with master node http://localhost:11311
[xmlrpc][INFO] 2018-11-09 15:34:01,339: xml rpc node: starting XML-RPC server
[rospy.init][INFO] 2018-11-09 15:34:01,438: registered with master
[rospy.rosout][INFO] 2018-11-09 15:34:01,438: initializing /rosout core topic
[rospy.rosout][ERROR] 2018-11-09 15:34:01,439: Unable to initialize /rosout: cannot use a string pattern on a bytes-like object
File “/opt/ros/melodic/lib/python3.7/site-packages/rospy/impl/rosout.py”, line 70, in init_rosout
_rosout_pub = Publisher(_ROSOUT, Log, latch=True, queue_size=100)
File “/opt/ros/melodic/lib/python3.7/site-packages/rospy/topics.py”, line 842, in init
super(Publisher, self).init(name, data_class, Registration.PUB)
File “/opt/ros/melodic/lib/python3.7/site-packages/rospy/topics.py”, line 146, in init
if not rosgraph.names.is_legal_name(name):
File “/opt/ros/melodic/lib/python3.7/site-packages/rosgraph/names.py”, line 233, in is_legal_name
m = NAME_LEGAL_CHARS_P.match(name)
TypeError: cannot use a string pattern on a bytes-like object
This error is very confusing because if we had a look at the code, it will be the following:
_clock_sub = rospy.topics.Subscriber(_ROSCLOCK, Clock, _set_rostime_clock_wrapper, queue_size=1)
