I’m using cube orange plus flight controller. I’m trying to setup battery parameters. It’s showing parameters missing in firmware. Firmware has bug in it. What should I do???
What firmware flavor and version are you running on the cube orange?
I’m using px4 pro v1.15.2 and bootloader version 5 over my cube orange plus flight controller.
Thank you for your support problem now solved.
This issue happened due to selection of Bat1_source to "External ". I changed the parameter to “power module” and it starts working.
