Arming rejected in offboard mode
Hi all,
I’m running px4 6x with release/1.14
Trying to offboard control via ros2 package
I was able to connect and see topics using uxrce dds agent
Now I’m trying to control the px4 with velocity contoller.
I tried to arm from keyboard but no luck.
I also tried to arm via qgc but denied as below picture shows.
arm2
I set “Allow arming without GPS” params
What is the reason px4 rejects arming?
Any suggestions?
@Kyuhyong_You Are you trying to do position or velocity control without a local position estimate?
Hi @Jaeyoung-Lim
Yes I’m only trying to test the board without GPS
One thing I noticed is that there is no RX packets received to uxrce_dds_client.
I checked uxrce_dds_client status in nsh I see no RX as below
nsh> uxrce_dds_client status
INFO  [uxrce_dds_client] Running, connected
INFO  [uxrce_dds_client] Using transport: serial
INFO  [uxrce_dds_client] Payload tx: 50139 B/s
INFO  [uxrce_dds_client] Payload rx: 0 B/s
When commanded to ARM via ros2 message as below
$ ros2 topic echo /fmu/in/vehicle_command
timestamp: 1699259008732148
param1: 1.0
param2: 0.0
param3: 0.0
param4: 0.0
param5: 0.0
param6: 0.0
param7: 0.0
command: 400
target_system: 1
target_component: 1
source_system: 1
source_component: 1
confirmation: 0
from_external: true
Seems like arming message is sent to micro_ros_agent but not to the dds_client on px4 finally.
Tried to check the topics of below message
/fmu/out/vehicle_status
/fmu/out/failsafe_flags
I found safety flags indicate there is no control signals available to px4.
offboard_control_signal_lost: true
home_position_invalid: true
manual_control_signal_lost: true
Why this happens while connected via uxrc agent?
Any idea?
You have here 2 code that are able to control a drone through position and velocity:
Some explications here:
and a demonstrative video here:
Hello @mdobrea
Thanks for sharing the repository.
Can you tell what version of ROS you used?
Have you tried to control px4 drone with uxrce_agent?
Did you also connect to uxrce client via serial port? What baud rate did you use?
Kyuhyong
Hi @Kyuhyong_You
ros2 run px4_ros_com offboard_control works
now rx payload is received to the dds_client.
INFO  [uxrce_dds_client] Payload tx: 51215 B/s
INFO  [uxrce_dds_client] Payload rx: 799 B/s
Maybe my offboard control from below is outdated?
Hi @Benja ,
I followed offboard control example you suggested but still could not arm the real hardware PX4.
There is no popups in the qgc.
What else I can do?
Hi @Kyuhyong_You,
Did you ever figure this out? I am having the same exact problem - can’t arm with any offboard script that I run.
