Good Day,
Does someone have an idea on how to configure the ADSB-IN type on the orange CUBE using a Px4 stack and QGC platform .
Also where do you read the received information from the ADSB-IN type module.
thank you
Good Day,
thank you
In the current master, the ADSB receiver is already configured out of the box. When a message is received, it will be relayed over mavlink in the form of an ADSB message
I’m not sure how QGroundControl reacts to receiving such a message
is it in the Mavlink console ?
If you go to analyze tools > mavlink inspector, if an ADSB message comes in, you should be able to see it pop up there for sure.
Can you advise on how to enable the console again for the Cube Orange? I need to see the debug port messaging, beyond the QGC Mavlink console. There was an _console build config back in 1.11. Any quick advice would be greatly appreciated. Thanks!
EDIT: Nevermind… I see that the “_console” configs became “_test” configs. Problem solved.
