I keep getting the warning ‘Accel 0 clipping, not safe to fly!’ whenever I fly my drone in manual, position, or mission mode. I checked that every part of the body is tied properly, and visually I don’t see any excessive vibration in the body. Also, I’m using damper screws to install the flight controller. Can anybody advise on the issue?
Can you share a picture of the drone (especially how the autopilot is mounted)?
It seems that the horizontal vibrations are stronger (Y axis is clipping the most), did you balance the propellers?
