Hi Guys,
Temperature, it looks like the PIXRACER gets affected by cold, or at least, when going outside and coming back inside our shack, etc. Yesteday temperature was like -10oC (14oF).
As per my understanding, compass is/should be Temperature compensated and it looks like this brutal temperature transition doesn’t help it. I was unable to arm the vehicule, I took QGC and the error was a mag 2 error. So, I have recalibrated the compas, it armed and it worked.
At some point we left the machine outside and it solved the issue.
So…. it is definitely temperature related. Unless it is the external compass in the the HK M8N GPS that creates the issue.
Any advice regarding Winter Conditions? How do yo manage this?
regards,
pturcotte
