Why do some parameters in PX4 get reset after reflashing the firmware?
I noticed that when I flash the firmware, parameters like SYS_CTRL_ALLOC (parameter that enables control allocation, documented here) get reset.
This causes the vehicle not knowing which airframe it has & user needing to setup the airframe from the beginning.
p.s. Battery cell count parameter is also reset, so user needs to configure that as well :wink:
Why is this happening?
From which to which version did you flash? They should not generally reset but in case a prameter did not exist before and you flash back and forth or there is some explicit transition set up like e.g. here: PX4-Autopilot/param_translation.cpp at 19b9b052ab59f06b2336f03cde42c2f498bf63d3 路 PX4/PX4-Autopilot 路 GitHub those could be reasons why they get changed when flashing. For the battery cell count there was some specific compatibility transition logic that got removed here: delete deprecated BAT_* parameters by dagar 路 Pull Request #16382 路 PX4/PX4-Autopilot 路 GitHub so that might be related depnding on the version.
