Meeting Minutes:
PX4 Dev Call - March 28 2017
What features are in release? Where is it documented?
Mathieu (new person) getting up to speed on PX4 VTOL
Goal to release next week
Want to fix Snapdragon and Aero before release
Snapdragon Issues: https://github.com/PX4/Firmware/issues?q=is%3Aopen+is%3Aissue+label%3Asnapdragon
Aero Issues: https://github.com/PX4/Firmware/issues?utf8=%E2%9C%93&q=is%3Aissue%20is%3Aopen%20Aero
Devs need to do a better job tagging issues.
Kanban boards should be working (where?)
Need a summary of gating issues for all repositories
Wanted something like this: https://github.com/orgs/PX4/projects/1
VTOL
Changes are improvements to quality of flight
Some safety related issues
Quadshute
- Good to get in release
Mostly fine tuning
Changes not release gating
More work on master
- Should be Matir’s focus
Are issues marked Critical flagged for release?
- Are people paying attention to the tags?
What prep is needed for the dev call?
List of critical issues
List of release gating issues
Snapdragon
Testing with Christophe
Cross test
Not gating release on optic flow
Aero
BSP is more stable
Altitude hold
- Need to resolve issue
Yaw happening
- Calibration issue?
David has setup test environment for ?
Mission takeoff - copter sits on ground for a while, then it shoots up into the sky
Lorenz - Likely HW throttle issue
- Need to tune altitude controller
What changed?
Need to document that new release requires new tuning or this behavior can occur
Lorenz: should not see a difference if you have a standard airframe
Parameters page on pixhawk needs to be updated.
- File new issue
FastRTPS
What is the philosophy on parameters?
Lorenz: The less parameters, the more automation
Tuning 30 parameters is error prone and only experts likely to get it right
Core dev team needs to do the tuning
- Seems not-scalable
Having fewer parameters seems likely more scalable
Can we have parameter nesting?
- Need to hide complexity
Piers: Another philosophy would be that the more parameters there are, the more flexible the configuration of the platform is. For me, the question is: can the default values for those parameters be sensibly set e.g. on a group, platform or airframe type basis? Appropriate configuration of default parameter values, coupled with a good tuning guide might provide a scalable solution.
Need to announce times on when to test current stuff vs new stuff
Need landing page for release info
- Hamish working on it
Creating schedule for predictable releases
Set feature freeze data
- Use “enhancement”, “bugfix”, etc on fixes
Clearly we need a document on development flow, how to tag, etc.
SITL and integrating rotors
Lorenz: Almost done re-integration
PX4 ROS not being tested in CI anymore
Building rotors is a pain
Only need 2 pkgs but need to clone whole repo
Use existing PR
- Use additional flag for ROS build
SITL Gazebo repo work
Causing code drift?
Need core plugins pushed upstream to Gazebo
Lorenz to follow up with OSRF
Are we providing what OSRF needs for testing (vs what Ardupilot gives them)
Vili working on
Have 2 people working (part time) on it
Need to work out plan for FastRTPS and QGC
- What is the end goal?
