I am testing this configuration without any motors by monitoring the servo outputs on QCG interface. My problem is that in MC mode the aileron on 5 & 6 respond correctly but when i transition to FW mode none of the servo output respond to any command.
Does it fully complete transition? What flight mode are you in?
Why can I not fly with vertical and vertical wings?Why do you only have two motors spinning?It’s the same motor in the same direction。
