Hi all,
I want to simulate motor failure in gazebo on a quadcopter
I understand that a plugin is already made for this but I have no idea how to use it. I have built it by modifying the CMakeFile but how would I actually go about using it?
Hi all,
You can interface it through the gazebo topics by sending the motor number
I wasnt too sure on how to publish to a gazebo topic, but I thought the plugin existed so I could publish to the ros topic and that would publish to gazebo. However I dont see the corresponding ros topic so I was not sure how to publish to that.
If you are using ROS, you can interact with ROS topics: https://github.com/PX4/sitl_gazebo/blob/f9bc7e34a754b6f204a8b3825c2b132587574cba/src/gazebo_motor_failure_plugin.cpp#L74
The issue I am facing is that I dont see the ROS topic for motor failure, so I am not sure if the plugin is even running. I know it built but do I need to check an option or modify the launch files to enable it?
Thanks a lot for your help btw I reallt appreciate it
@steelshot Ah, of course you need to add the plugin to the model
Ahh I see. Do you have any pointers on how to do that? I am kind of new to gazebo.
Have you solved this problem by any chance?
My goal is to break it down. To be more specific, my goal is to move the drone to the desired setpoint and stop one motor in real time or control the speed.
But I thought it was impossible to control the px4 code because I’m a ros beginner.
I was looking for a way, and if I look at iris.sdf
/gazebo/command/motor_speed
/motor_speed/0
There’s a code called that.
So I thought there was something about exchanging these topics and when I looked, I found the gazebo_motor_model.cpp, gazebo_motor_model.h file.
However, I have a question that I can modify these files to control iris in gazebo.
What I thought was that you can control the motor by sub or sub here, and you can use this to control the motor in real time.
I’m wondering if this is right, and if it is, I’d like to know how to do it in detail…
Any follow up on it ? I am looking to do something similar. Will help a lot
Thank you for your response.
I would like to implement Fault Tolerant Control. However, in the gazebo_motor_failure_plugin.cpp file, it seems that it only simulates motor failure without transmitting motor failure information to the PX4 Firmware. As a result, I noticed that the control allocation matrix is not being reconfigured. It merely stops the motor, but the PX4 Firmware doesn’t recognize the failure.
Thus, I believe the module in the PX4 Firmware needs to be modified. How can I reconfigure the control allocation matrix in this case? Which module or file should I modify in the code? Additionally, I would like to know the function or line of code that generates the control allocation matrix.
I apologize for asking so many questions upon our first interaction, and I’m not sure if I’ve asked them correctly. Thank you for taking the time to read this long message!
This might help. Ig you have to override the mixers with your own mixer
