ihi’ i try to install px4 on the kakute f7 aio v1.5 ’ i
the flashing is work but after i connect again the board and try to use QGC i dont get any madia about the flight controler
thanks for the help
Have you enabled auto-connection in QGC?
hi, i dont think this is the problem
i try with my both cumputer - linux and windows and tis not work …
Something is wrong. I think you have the wrong bootloader. It says fmu-v2 in your update screenshot but it should say something with kakute f7.
When I flash Ardupilot with the px4 console the Ardupilot work
And it’s recognize the board as kakute
So I don’t understand why it’s not flash the px4 also
Maby I need to flash not the standard px4?
ok i use the bin file and flash the bootloader from the STM32CUBEprogramer
then when i go to the PX4 and try to flash the program the px4 sucsees to flash but when i connect to the cumputer again the flight control dont connect
when i flash it with ardupilot its work
did some one have any idia ??
Have you tried a full erase before flashing the bootloader?
