Use Custom IMU for EKF2
I want to PX4’s EKF2 use AI-corrected IMU data instead of the raw sensor stream.
My intended flow is: /mavros/imu/data → AI model (denoising/filtering) → UDP port 14560 → vehicle_imu_ai (uORB) → EKF2
Issue
From a structural point of view, publishing data through the vehicle_imu_ai topic is correct — the message format and timing fields match vehicle_imu.
However, once EKF2’s IMU source is switched to vehicle_imu_ai, two major problems occur.
  1. EKF2 logs poll timeout 0, 22
After setting EKF2_IMU_SRC=1, EKF2 stops receiving IMU updates at the expected rate.
  • The AI IMU feed currently runs at about 35 Hz, which is much slower and less regular than the default IMU rate (~200 Hz).
  • PX4’s scheduler waits for IMU updates that don’t arrive on time, so it logs poll timeouts.
  • As a result, EKF2 stops updating because the AI data is too slow or inconsistent.
  1. /mavros/imu/data drops to ~1 Hz after switching to AI
Immediately after switching EKF2 to use vehicle_imu_ai, the /mavros/imu/data topic slows to ~1 Hz ~ only heartbeat messages remain.
This likely happens because EKF2 unsubscribes from the raw vehicle_imu topic once it switches to the AI feed.
In SITL, if no one is subscribed, the simulator stops publishing IMU data.
Consequences:
  • MAVROS loses high-rate IMU data and pose updates stop.
  • The AI inference script stops receiving IMU input and therefore stops sending corrected data.
  • EKF2 then times out waiting for new vehicle_imu_ai samples, and the entire estimation pipeline halts.
Have you tested this with ROS2? It will pass the mavros, so you don’t have to go through mavros. might it save some time delays
No I’m actually using ROS1 Noetic
I suggest switching to ROS 2. Also check PX4 Neural Networks
Can you explain a little more? Have you tried this before?
Edit 1: I have managed to increase my AI IMU rate from the previous 35Hz, but the issue is that SITL IMU Data (input to the AI model) stops when I switch to AI Mode.
