I’m designing a coxial octocopter which needs to be used for a research project. To try and get understand coaxial octocopter better I made a simulation in Gazebo using one. I managed to get it to fly, but it flies very unstable. I noticed in the flight log that the roll and pitch angle estimate is different from the ground truth. Not sure what can cause this, so any ideas is appreciated. I have also linked the flight log.
https://review.px4.io/plot_app?log=f9d2c7a4-a7bf-4722-9775-4d43d2a818b3
Furthermore, I also discovered that if I lower the weight of the simulated drone a bit it will start flying even more unstable and crash. The drone will also takeoff even just using the arm command. Again any ideas for the reason are appreciated.
