Hello Roman,
thanks for your reply!
[[quote=“tumbili, post:4, topic:398, full:true”]
P.S. You were also asking about the parameter which would not be changed by the sliders. I’ve never tried it @LorenzMeier Have you played with this?[/quote]
Do I understand well, that you work directly with the parameters and not with the sliders at all?
Hi Hendrik,I think your basic understanding of tuning the loops is right. However, there is not one right tuning.It depends on what you want to optimise. Do you want to have as little overshoot as possible or do you just want to be fast.[/quote]
I’m not sure… If I accept overshoot, will that not always lead to oszillations?
Anyway: In my case, I do not see any overshoot. BUT: The copter is way to agile. This way, I cause overshoot, and by that Pilot Induced Oszillations (PIO). This has nothing to do with PID. Just imagine going 180km/h (or whatever is allowed in your contry
with your car. And now a movement of the steering-wheel of 3° rotates the wheels by 20°.
This will lead to oszillations, but this is not caused by too high PID Gains. It is purely caused by the driver. I have the impression, that this is my problem.
Of course, this CAN be mitigated by lower gains… But this is not the root cause. The root cause is that the Pilot (me) is not able to use the sticks accurately enough. BUT: The outer loop controller (aka stabilize) can use the controlls accurately enough. By reducing the gains of the inner loop, we limit the agility of the copter, trying to overcome our (=the humans) limitation. But in doing this, we also limit what the stabilize controller can do.
You are right: This can be done. But another way to fix this -and I think this would fix the root cause- is to add some expo in Acro. This should result in a better control in stabilize.
Does this make sense, or am I missing something?
Although my copter is a H680, i.e. three times as big?
[quote]If your rate loop is tuned well then in Acro mode you will see the vehicle locking into the orientations.If you let go of the stick it should just hold that orientation and you should see minimal drift. [quote]
Yes, I do. But I do not see minimal drift, but strong drift. This is, because a slight input on the RC leads to a high roll angle. Thus, the drift is strong. But: yes, the locking of the orientation is very good.
I’ll try. After your confirmation that it’s a good idea despite the large difference in size.
When were the gains updated? I am using the beta from last weekend.
Greetings,
Hendrik
