I am raising this post as I recently noticed funny behavior when using MavLink command to reset the Pixhawk board. After resetting, the Pixhawk does not always return the HOME position (MAVLINK_MSG_ID_HOME_POSITION) back to the QGroundControl GCS.
Here are the steps I followed:
- Use QGC to send the Mavlink command:
_vehicle->doCommandLong(defaultComponentId(), MAV_CMD_PREFLIGHT_REBOOT_SHUTDOWN, 1.0f, 0.0f, 0.0f, 0.0f, 0.0f, 0.0f, 0.0f);
- Pixhawk reboots, QGC is up again.
- Does not consistently receive the MAVLINK_MSG_ID_HOME_POSITION back, on each retry.
- Home location is not set on the GCS when connected with HIL (e.g. X-Plane)
On the Pixhawk side, this is how it is received:
if (cmd_mavlink.command == MAV_CMD_PREFLIGHT_REBOOT_SHUTDOWN && ((int)cmd_mavlink.param1) == 10) {
/* This is the link shutdown command, terminate mavlink */
warnx(“terminated by remote”);
fflush(stdout);
usleep(50000);
/* terminate other threads and this thread */
_mavlink->_task_should_exit = true;
This makes me curious as to how PX4 handles this scenario of reset (flushing buffer and restarting MavLink?) and makes me wonder if that is indeed a bug with PX4 not being in the right initial state? Please notice that “resetting” the board via software is different than just disconnecting/connecting the hardware.
Any comment on this observation is appreciated.
Thanks,
Shyam
