Hello, I’m trying to run the QGC build for Android on QT. The Desktop build works just fine with MSCV 2019. When I try to compile the android build, i get the following error:
/usr/bin/sh: C:UsersaryanAppDataLocalAndroidSdkndk21.3.6528147/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++: No such file or directory
make[1]: *** [Makefile.Arm64-v8a:2411: arm64-v8a/qrc_qgroundcontrol.obj] Error 127
make[1]: *** [Makefile.Armeabi-v7a:2411: armeabi-v7a/qrc_qgroundcontrol.obj] Error 127
I cant’t solve this error. The android SDK’s are installed correctly and the compiler paths are also correct. In fact even other QT examples build fine for android, its just QGC which gives an error… I cant understand why it is utilizing that invalid path without any slashes in it. Any help would be appreciated, thank you.
