While we creating the QGC Android build In Windows we are getting the following error and could not resolve it and the environment details given below:
Andriod build in Windows Platform
JDK 11.0.16.1
ndk 21
SDK 31
gradle version in gradle.properties - 7.3.3
gradle version in build.gradle - 2.3.0
Qt creator 5.15.2
Android ARMv7
Build: QGC stable build-4.1
Error:
FAILURE: Build failed with an exception.
- What went wrong:
A problem occurred configuring root project ‘android-build’.
Failed to notify project evaluation listener.
javax/xml/bind/annotation/XmlSchema
- Try:
Run with --stacktrace option to get the stack trace.
Run with --debug option to get more log output.
Run with --scan to get full insights.
- Get more help at https://help.gradle.org
Deprecated Gradle features were used in this build, making it incompatible with Gradle 8.0.
You can use ‘–warning-mode all’ to show the individual deprecation warnings and determine if they come from your own scripts or plugins.
BUILD FAILED in 12s
Watched directory hierarchies:
Building the android package failed!
12:07:58: The process “C:\Qt\5.15.2\android\bin\androiddeployqt.exe” exited with code 14.
Error while building/deploying project qgroundcontrol (kit: Android Qt 5.15.2 Clang Multi-Abi)
The kit Android Qt 5.15.2 Clang Multi-Abi has configuration issues which might be the root cause for this problem.
When executing step “Build Android APK”
12:07:58: Elapsed time: 01:23.
