Pretty much what the topic says, any ways to solve this?
swarm_researchers@swarm-Alienware-Aurora-R16:~/PX4-Autopilot$ make px4_sitl
-- PX4 version: v1.15.0-beta1-90-g253208fdd4 (1.15.0)
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.10.12", minimum required is "3")
-- PX4 config file: /home/swarm_researchers/PX4-Autopilot/boards/px4/sitl/default.px4board
-- PLATFORM posix
-- ROMFSROOT px4fmu_common
-- ROOTFSDIR .
-- TESTING y
-- ETHERNET y
-- PX4 config: px4_sitl_default
-- PX4 platform: posix
-- PX4 lockstep: enabled
-- The CXX compiler identification is GNU 11.4.0
-- The C compiler identification is GNU 11.4.0
-- The ASM compiler identification is GNU
-- Found assembler: /usr/bin/cc
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- cmake build type: RelWithDebInfo
/usr/bin/python3: Error while finding module specification for 'symforce.symbolic' (ModuleNotFoundError: No module named 'symforce')
-- Could NOT find gz-transport (missing: gz-transport_DIR)
-- Looking for gz-transport12 -- found version 12.2.1
-- Searching for dependencies of gz-transport12
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so (found version "3.21.12")
-- Config-file not installed for ZeroMQ -- checking for pkg-config
-- Checking for module 'libzmq >= 4'
-- Found libzmq , version 4.3.4
-- Found ZeroMQ: TRUE (Required is at least version "4")
-- Checking for module 'uuid'
-- Found uuid, version 2.37.2
-- Found UUID: TRUE
-- Looking for gz-utils2 -- found version 2.2.0
-- Searching for dependencies of gz-utils2
-- Searching for <gz-utils2> component [cli]
-- Looking for gz-utils2-cli -- found version 2.2.0
-- Searching for dependencies of gz-utils2-cli
-- Looking for gz-msgs9 -- found version 9.5.0
-- Searching for dependencies of gz-msgs9
-- Looking for gz-math7 -- found version 7.4.0
-- Searching for dependencies of gz-math7
-- Checking for module 'tinyxml2'
-- Found tinyxml2, version 9.0.0
-- Found Java: /usr/bin/java (found version "11.0.22")
-- ROMFS: ROMFS/px4fmu_common
Architecture: amd64
==> CPACK_INSTALL_PREFIX = @DEB_INSTALL_PREFIX@
-- Configuring done
-- Generating done
-- Build files have been written to: /home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default
[0/1029] git submodule src/modules/uxrce_dds_client/Micro-XRCE-DDS-Client
[2/1029] git submodule src/drivers/gps/devices
[8/1029] git submodule src/modules/mavlink/mavlink
[705/1029] Building CXX object src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZBridge.cpp.o
FAILED: src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZBridge.cpp.o
/usr/bin/c++ -DCONFIG_ARCH_BOARD_PX4_SITL -DENABLE_LOCKSTEP_SCHEDULER -DMODULE_NAME=\"gz_bridge\" -DPX4_MAIN=gz_bridge_app_main -D__CUSTOM_FILE_IO__ -D__PX4_LINUX -D__PX4_POSIX -D__STDC_FORMAT_MACROS -Dnoreturn_function="__attribute__((noreturn))" -I/home/swarm_researchers/PX4-Autopilot/boards/px4/sitl/src -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/src/px4/common/include -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default/src/lib -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/src/px4/generic/generic/include -I/home/swarm_researchers/PX4-Autopilot/platforms/common -I/home/swarm_researchers/PX4-Autopilot/platforms/common/include -I/home/swarm_researchers/PX4-Autopilot/src -I/home/swarm_researchers/PX4-Autopilot/src/include -I/home/swarm_researchers/PX4-Autopilot/src/lib -I/home/swarm_researchers/PX4-Autopilot/src/lib/matrix -I/home/swarm_researchers/PX4-Autopilot/src/modules -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/include -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default/external/Install/include -isystem /usr/include/gz/transport12 -isystem /usr/include/gz/utils2 -isystem /usr/include/gz/msgs9 -isystem /usr/include/gz/math7 -isystem /usr/include/uuid -O2 -g -DNDEBUG -fPIC -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -Wno-stringop-truncation -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -Wreorder -Wno-overloaded-virtual -frtti -fexceptions -O2 -I/usr/include/uuid -std=gnu++17 -MD -MT src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZBridge.cpp.o -MF src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZBridge.cpp.o.d -o src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZBridge.cpp.o -c /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZBridge.cpp
In file included from /usr/include/gz/msgs9/gz/msgs/pointcloud_packed.pb.h:17,
from /usr/include/gz/msgs9/gz/msgs/detail/PointCloudPackedUtils.hh:24,
from /usr/include/gz/msgs9/gz/msgs.hh:23,
from /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZMixingInterfaceESC.hpp:38,
from /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZBridge.hpp:36,
from /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZBridge.cpp:34:
/usr/include/gz/msgs9/gz/msgs/details/pointcloud_packed.pb.h:17:2: error: #error This file was generated by an older version of protoc which is
17 | #error This file was generated by an older version of protoc which is
compilation terminated due to -Wfatal-errors.
[707/1029] Building CXX object src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceESC.cpp.o
FAILED: src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceESC.cpp.o
/usr/bin/c++ -DCONFIG_ARCH_BOARD_PX4_SITL -DENABLE_LOCKSTEP_SCHEDULER -DMODULE_NAME=\"gz_bridge\" -DPX4_MAIN=gz_bridge_app_main -D__CUSTOM_FILE_IO__ -D__PX4_LINUX -D__PX4_POSIX -D__STDC_FORMAT_MACROS -Dnoreturn_function="__attribute__((noreturn))" -I/home/swarm_researchers/PX4-Autopilot/boards/px4/sitl/src -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/src/px4/common/include -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default/src/lib -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/src/px4/generic/generic/include -I/home/swarm_researchers/PX4-Autopilot/platforms/common -I/home/swarm_researchers/PX4-Autopilot/platforms/common/include -I/home/swarm_researchers/PX4-Autopilot/src -I/home/swarm_researchers/PX4-Autopilot/src/include -I/home/swarm_researchers/PX4-Autopilot/src/lib -I/home/swarm_researchers/PX4-Autopilot/src/lib/matrix -I/home/swarm_researchers/PX4-Autopilot/src/modules -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/include -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default/external/Install/include -isystem /usr/include/gz/transport12 -isystem /usr/include/gz/utils2 -isystem /usr/include/gz/msgs9 -isystem /usr/include/gz/math7 -isystem /usr/include/uuid -O2 -g -DNDEBUG -fPIC -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -Wno-stringop-truncation -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -Wreorder -Wno-overloaded-virtual -frtti -fexceptions -O2 -I/usr/include/uuid -std=gnu++17 -MD -MT src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceESC.cpp.o -MF src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceESC.cpp.o.d -o src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceESC.cpp.o -c /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZMixingInterfaceESC.cpp
from /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZMixingInterfaceESC.cpp:34:
[708/1029] Building CXX object src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceWheel.cpp.o
FAILED: src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceWheel.cpp.o
/usr/bin/c++ -DCONFIG_ARCH_BOARD_PX4_SITL -DENABLE_LOCKSTEP_SCHEDULER -DMODULE_NAME=\"gz_bridge\" -DPX4_MAIN=gz_bridge_app_main -D__CUSTOM_FILE_IO__ -D__PX4_LINUX -D__PX4_POSIX -D__STDC_FORMAT_MACROS -Dnoreturn_function="__attribute__((noreturn))" -I/home/swarm_researchers/PX4-Autopilot/boards/px4/sitl/src -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/src/px4/common/include -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default/src/lib -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/src/px4/generic/generic/include -I/home/swarm_researchers/PX4-Autopilot/platforms/common -I/home/swarm_researchers/PX4-Autopilot/platforms/common/include -I/home/swarm_researchers/PX4-Autopilot/src -I/home/swarm_researchers/PX4-Autopilot/src/include -I/home/swarm_researchers/PX4-Autopilot/src/lib -I/home/swarm_researchers/PX4-Autopilot/src/lib/matrix -I/home/swarm_researchers/PX4-Autopilot/src/modules -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/include -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default/external/Install/include -isystem /usr/include/gz/transport12 -isystem /usr/include/gz/utils2 -isystem /usr/include/gz/msgs9 -isystem /usr/include/gz/math7 -isystem /usr/include/uuid -O2 -g -DNDEBUG -fPIC -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -Wno-stringop-truncation -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -Wreorder -Wno-overloaded-virtual -frtti -fexceptions -O2 -I/usr/include/uuid -std=gnu++17 -MD -MT src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceWheel.cpp.o -MF src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceWheel.cpp.o.d -o src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceWheel.cpp.o -c /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZMixingInterfaceWheel.cpp
from /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZMixingInterfaceWheel.hpp:38,
from /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZMixingInterfaceWheel.cpp:34:
[710/1029] Building CXX object src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceServo.cpp.o
FAILED: src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceServo.cpp.o
/usr/bin/c++ -DCONFIG_ARCH_BOARD_PX4_SITL -DENABLE_LOCKSTEP_SCHEDULER -DMODULE_NAME=\"gz_bridge\" -DPX4_MAIN=gz_bridge_app_main -D__CUSTOM_FILE_IO__ -D__PX4_LINUX -D__PX4_POSIX -D__STDC_FORMAT_MACROS -Dnoreturn_function="__attribute__((noreturn))" -I/home/swarm_researchers/PX4-Autopilot/boards/px4/sitl/src -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/src/px4/common/include -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default/src/lib -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/src/px4/generic/generic/include -I/home/swarm_researchers/PX4-Autopilot/platforms/common -I/home/swarm_researchers/PX4-Autopilot/platforms/common/include -I/home/swarm_researchers/PX4-Autopilot/src -I/home/swarm_researchers/PX4-Autopilot/src/include -I/home/swarm_researchers/PX4-Autopilot/src/lib -I/home/swarm_researchers/PX4-Autopilot/src/lib/matrix -I/home/swarm_researchers/PX4-Autopilot/src/modules -I/home/swarm_researchers/PX4-Autopilot/platforms/posix/include -I/home/swarm_researchers/PX4-Autopilot/build/px4_sitl_default/external/Install/include -isystem /usr/include/gz/transport12 -isystem /usr/include/gz/utils2 -isystem /usr/include/gz/msgs9 -isystem /usr/include/gz/math7 -isystem /usr/include/uuid -O2 -g -DNDEBUG -fPIC -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -Wno-stringop-truncation -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -Wreorder -Wno-overloaded-virtual -frtti -fexceptions -O2 -I/usr/include/uuid -std=gnu++17 -MD -MT src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceServo.cpp.o -MF src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceServo.cpp.o.d -o src/modules/simulation/gz_bridge/CMakeFiles/modules__simulation__gz_bridge.dir/GZMixingInterfaceServo.cpp.o -c /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZMixingInterfaceServo.cpp
In file included from /usr/include/gz/msgs9/gz/msgs/discovery.pb.h:17,
from /usr/include/gz/transport12/gz/transport/Discovery.hh:59,
from /usr/include/gz/transport12/gz/transport.hh:26,
from /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZMixingInterfaceServo.hpp:38,
from /home/swarm_researchers/PX4-Autopilot/src/modules/simulation/gz_bridge/GZMixingInterfaceServo.cpp:34:
/usr/include/gz/msgs9/gz/msgs/details/discovery.pb.h:17:2: error: #error This file was generated by an older version of protoc which is
[738/1029] Building CXX object src/modules/replay/CMakeFiles/modules__replay.dir/Replay.cpp.o
make: *** [Makefile:232: px4_sitl] Error 1
