Protoc error on build
I’ve been trying to build a simulation environment using these instructions
on Ubuntu 24.04.2 LTS
That seems to work but when I try:
make px4_sitl gz_x500
It fails and it seems to be from:
PX4-Autopilot/build/px4_sitl_default/src/modules/simulation/gz_msgs/opticalflow.pb.h:17:2: error: #error This file was generated by an older version of protoc which is
17 | #error This file was generated by an older version of protoc which is
compilation terminated due to -Wfatal-errors.
[452/738] Building CXX object src/modu…mulation__gz_bridge.dir/GZGimbal.cpp.o
make: *** [Makefile:232: px4_sitl] Error 1
I found some suggestions in other threads, to install an earlier version of protobuf but there doesn’t seem to be a release 17 of protobuf.
I’m also looking into rebuilding opticalflow with a more recent version of protoc but I haven’t figured that out either.
I was facing the same error while using Ubuntu 22.04 on WSL2.
However, I followed the steps below and the issue was successfully resolved:
Step 1: Remove the Existing Protobuf Version
First, completely remove the version of protobuf that was installed by the package manager.
sudo apt-get remove --purge protobuf-compiler libprotobuf-dev
sudo apt-get autoremove
Step 2: Download and Compile protoc 3.6.1 from Source
This will download the source code, compile it on your machine, and install it.
Navigate to your home directory
cd ~
Download the source code for version 3.6.1
wget https://github.com/protocolbuffers/protobuf/releases/download/v3.6.1/protobuf-all-3.6.1.tar.gz
Extract the archive
tar -xzf protobuf-all-3.6.1.tar.gz
Move into the extracted directory
cd protobuf-3.6.1
Configure the build (this prepares the makefiles)
./configure --prefix=/usr/local
Compile the source code using all available processor cores
make -j$(nproc)
Install the compiled files to your system
sudo make install
Update the shared library cache so the system can find the new files
sudo ldconfig
Step 3: Verify the Installation
Check that the correct version is now active on your system.
protoc --version
Step 4: Clean the PX4 Project Directory
You must remove all old build files from your PX4 project that were created with the previous protoc version.
cd ~/PX4-Autopilot
make distclean
Step 5: Restart WSL
A full restart of the WSL instance is crucial to ensure all changes are applied correctly.
  1. Close your WSL terminal or type exit.
  2. Open a Windows Command Prompt (cmd) or PowerShell and execute: PowerShellwsl --shutdown
  3. Wait a few seconds, then open a new WSL terminal.
Step 6: Attempt the Build Again
Navigate back to your project folder and try to build PX4 SITL.
cd ~/PX4-Autopilot
make px4_sitl
