Thanks @Ranjeet . i install the latest protobuf following this page
Now, the error changes…
[0/4] Performing build step for 'sitl_gazebo' [1/91] Building CXX object CMakeFiles/sensor_msgs.dir/Range.pb.cc.o FAILED: CMakeFiles/sensor_msgs.dir/Range.pb.cc.o /usr/bin/c++ -DLIBBULLET_VERSION=2.87 -DLIBBULLET_VERSION_GT_282 -Dsensor_msgs_EXPORTS -isystem /usr/include/gazebo-9 -isystem /usr/include/bullet -isystem /usr/include/simbody -isystem /usr/local/include -isystem /usr/include/sdformat-6.2 -isystem /usr/include/ignition/math4 -isystem /usr/include/OGRE -isystem /usr/include/OGRE/Terrain -isystem /usr/include/OGRE/Paging -isystem /usr/include/ignition/transport4 -isystem /usr/include/ignition/msgs1 -isystem /usr/include/ignition/common1 -isystem /usr/include/ignition/fuel_tools1 -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -isystem /usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -I/home/sique/src/Firmware/Tools/sitl_gazebo/include -I. -I/usr/include/eigen3 -I/usr/include/eigen3/eigen3 -I/usr/include/gazebo-9/gazebo/msgs -I/home/sique/src/Firmware/mavlink/include -isystem /usr/include/opencv -I/home/sique/src/Firmware/Tools/sitl_gazebo/external/OpticalFlow/include -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -isystem /usr/include/uuid -isystem /usr/include/x86_64-linux-gnu -O2 -g -DNDEBUG -fPIC -Wno-deprecated-declarations -Wno-address-of-packed-member -I/usr/include/uuid -I/usr/include/x86_64-linux-gnu -std=gnu++1z -MD -MT CMakeFiles/sensor_msgs.dir/Range.pb.cc.o -MF CMakeFiles/sensor_msgs.dir/Range.pb.cc.o.d -o CMakeFiles/sensor_msgs.dir/Range.pb.cc.o -c Range.pb.cc In file included from Range.pb.h:35:0, from Range.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:17:2: error: #error This file was generated by an older version of protoc which is #error This file was generated by an older version of protoc which is ^~~~~ /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:18:2: error: #error incompatible with your Protocol Buffer headers. Please #error incompatible with your Protocol Buffer headers. Please ^~~~~ /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:19:2: error: #error regenerate this file with a newer version of protoc. #error regenerate this file with a newer version of protoc. ^~~~~ In file included from Range.pb.h:35:0, from Range.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:158:33: error: ‘InternalMetadataWithArena’ in namespace ‘google::protobuf::internal’ does not name a type ::google::protobuf::internal::InternalMetadataWithArena _internal_metadata_; ^~~~~~~~~~~~~~~~~~~~~~~~~ /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h: In member function ‘const google::protobuf::UnknownFieldSet& gazebo::msgs::Quaternion::unknown_fields() const’: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:61:47: error: no matching function for call to ‘google::protobuf::internal::InternalMetadata::unknown_fields() const’ return _internal_metadata_.unknown_fields(); ^ In file included from /usr/local/include/google/protobuf/message_lite.h:49:0, from /usr/local/include/google/protobuf/generated_enum_util.h:36, from /usr/local/include/google/protobuf/map.h:55, from /usr/local/include/google/protobuf/generated_message_table_driven.h:34, from Range.pb.h:26, from Range.pb.cc:4: /usr/local/include/google/protobuf/metadata_lite.h:87:35: note: candidate: template<class T> const T& google::protobuf::internal::InternalMetadata::unknown_fields(const T& (*)()) const PROTOBUF_ALWAYS_INLINE const T& unknown_fields( ^~~~~~~~~~~~~~ /usr/local/include/google/protobuf/metadata_lite.h:87:35: note: template argument deduction/substitution failed: In file included from Range.pb.h:35:0, from Range.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:61:47: note: candidate expects 1 argument, 0 provided return _internal_metadata_.unknown_fields(); ^ /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h: In member function ‘google::protobuf::UnknownFieldSet* gazebo::msgs::Quaternion::mutable_unknown_fields()’: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:65:55: error: no matching function for call to ‘google::protobuf::internal::InternalMetadata::mutable_unknown_fields()’ return _internal_metadata_.mutable_unknown_fields(); ^ In file included from /usr/local/include/google/protobuf/message_lite.h:49:0, from /usr/local/include/google/protobuf/generated_enum_util.h:36, from /usr/local/include/google/protobuf/map.h:55, from /usr/local/include/google/protobuf/generated_message_table_driven.h:34, from Range.pb.h:26, from Range.pb.cc:4: /usr/local/include/google/protobuf/metadata_lite.h:97:29: note: candidate: template<class T> T* google::protobuf::internal::InternalMetadata::mutable_unknown_fields() PROTOBUF_ALWAYS_INLINE T* mutable_unknown_fields() { ^~~~~~~~~~~~~~~~~~~~~~ /usr/local/include/google/protobuf/metadata_lite.h:97:29: note: template argument deduction/substitution failed: In file included from Range.pb.h:35:0, from Range.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:65:55: note: couldn't deduce template parameter ‘T’ return _internal_metadata_.mutable_unknown_fields(); ^ In file included from Range.pb.cc:4:0: Range.pb.h: In member function ‘const gazebo::msgs::Quaternion& sensor_msgs::msgs::Range::_internal_orientation() const’: Range.pb.h:524:24: error: ‘_Quaternion_default_instance_’ is not a member of ‘gazebo::msgs’ &::gazebo::msgs::_Quaternion_default_instance_); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Range.pb.cc: At global scope: Range.pb.cc:17:8: error: ‘PROTOBUF_INTERNAL_EXPORT_quaternion_2eproto’ does not name a type; did you mean ‘PROTOBUF_INTERNAL_EXPORT_Range_2eproto’? extern PROTOBUF_INTERNAL_EXPORT_quaternion_2eproto ::PROTOBUF_NAMESPACE_ID::internal::SCCInfo<0> scc_info_Quaternion_quaternion_2eproto; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ PROTOBUF_INTERNAL_EXPORT_Range_2eproto Range.pb.cc:39:8: error: ‘scc_info_Quaternion_quaternion_2eproto’ was not declared in this scope &scc_info_Quaternion_quaternion_2eproto.base,}}; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Range.pb.cc:39:8: note: suggested alternative: ‘scc_info_Range_Range_2eproto’ &scc_info_Quaternion_quaternion_2eproto.base,}}; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ scc_info_Range_Range_2eproto Range.pb.cc:86:6: error: ‘::descriptor_table_quaternion_2eproto’ has not been declared &::descriptor_table_quaternion_2eproto, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Range.pb.cc:86:6: note: suggested alternative: ‘descriptor_table_Range_2eproto’ &::descriptor_table_quaternion_2eproto, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ descriptor_table_Range_2eproto Range.pb.cc: In static member function ‘static void sensor_msgs::msgs::Range::InitAsDefaultInstance()’: Range.pb.cc:108:35: error: ‘internal_default_instance’ is not a member of ‘gazebo::msgs::Quaternion’ ::gazebo::msgs::Quaternion::internal_default_instance()); ^~~~~~~~~~~~~~~~~~~~~~~~~ At global scope: cc1plus: warning: unrecognized command line option ‘-Wno-address-of-packed-member’ [2/91] Building CXX object CMakeFiles/sensor_msgs.dir/Imu.pb.cc.o FAILED: CMakeFiles/sensor_msgs.dir/Imu.pb.cc.o /usr/bin/c++ -DLIBBULLET_VERSION=2.87 -DLIBBULLET_VERSION_GT_282 -Dsensor_msgs_EXPORTS -isystem /usr/include/gazebo-9 -isystem /usr/include/bullet -isystem /usr/include/simbody -isystem /usr/local/include -isystem /usr/include/sdformat-6.2 -isystem /usr/include/ignition/math4 -isystem /usr/include/OGRE -isystem /usr/include/OGRE/Terrain -isystem /usr/include/OGRE/Paging -isystem /usr/include/ignition/transport4 -isystem /usr/include/ignition/msgs1 -isystem /usr/include/ignition/common1 -isystem /usr/include/ignition/fuel_tools1 -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -isystem /usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -I/home/sique/src/Firmware/Tools/sitl_gazebo/include -I. -I/usr/include/eigen3 -I/usr/include/eigen3/eigen3 -I/usr/include/gazebo-9/gazebo/msgs -I/home/sique/src/Firmware/mavlink/include -isystem /usr/include/opencv -I/home/sique/src/Firmware/Tools/sitl_gazebo/external/OpticalFlow/include -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -isystem /usr/include/uuid -isystem /usr/include/x86_64-linux-gnu -O2 -g -DNDEBUG -fPIC -Wno-deprecated-declarations -Wno-address-of-packed-member -I/usr/include/uuid -I/usr/include/x86_64-linux-gnu -std=gnu++1z -MD -MT CMakeFiles/sensor_msgs.dir/Imu.pb.cc.o -MF CMakeFiles/sensor_msgs.dir/Imu.pb.cc.o.d -o CMakeFiles/sensor_msgs.dir/Imu.pb.cc.o -c Imu.pb.cc In file included from Imu.pb.h:35:0, from Imu.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:17:2: error: #error This file was generated by an older version of protoc which is #error This file was generated by an older version of protoc which is ^~~~~ /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:18:2: error: #error incompatible with your Protocol Buffer headers. Please #error incompatible with your Protocol Buffer headers. Please ^~~~~ /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:19:2: error: #error regenerate this file with a newer version of protoc. #error regenerate this file with a newer version of protoc. ^~~~~ In file included from Imu.pb.h:36:0, from Imu.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h:17:2: error: #error This file was generated by an older version of protoc which is #error This file was generated by an older version of protoc which is ^~~~~ /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h:18:2: error: #error incompatible with your Protocol Buffer headers. Please #error incompatible with your Protocol Buffer headers. Please ^~~~~ /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h:19:2: error: #error regenerate this file with a newer version of protoc. #error regenerate this file with a newer version of protoc. ^~~~~ In file included from Imu.pb.h:35:0, from Imu.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:158:33: error: ‘InternalMetadataWithArena’ in namespace ‘google::protobuf::internal’ does not name a type ::google::protobuf::internal::InternalMetadataWithArena _internal_metadata_; ^~~~~~~~~~~~~~~~~~~~~~~~~ /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h: In member function ‘const google::protobuf::UnknownFieldSet& gazebo::msgs::Quaternion::unknown_fields() const’: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:61:47: error: no matching function for call to ‘google::protobuf::internal::InternalMetadata::unknown_fields() const’ return _internal_metadata_.unknown_fields(); ^ In file included from /usr/local/include/google/protobuf/message_lite.h:49:0, from /usr/local/include/google/protobuf/generated_enum_util.h:36, from /usr/local/include/google/protobuf/map.h:55, from /usr/local/include/google/protobuf/generated_message_table_driven.h:34, from Imu.pb.h:26, from Imu.pb.cc:4: /usr/local/include/google/protobuf/metadata_lite.h:87:35: note: candidate: template<class T> const T& google::protobuf::internal::InternalMetadata::unknown_fields(const T& (*)()) const PROTOBUF_ALWAYS_INLINE const T& unknown_fields( ^~~~~~~~~~~~~~ /usr/local/include/google/protobuf/metadata_lite.h:87:35: note: template argument deduction/substitution failed: In file included from Imu.pb.h:35:0, from Imu.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:61:47: note: candidate expects 1 argument, 0 provided return _internal_metadata_.unknown_fields(); ^ /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h: In member function ‘google::protobuf::UnknownFieldSet* gazebo::msgs::Quaternion::mutable_unknown_fields()’: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:65:55: error: no matching function for call to ‘google::protobuf::internal::InternalMetadata::mutable_unknown_fields()’ return _internal_metadata_.mutable_unknown_fields(); ^ In file included from /usr/local/include/google/protobuf/message_lite.h:49:0, from /usr/local/include/google/protobuf/generated_enum_util.h:36, from /usr/local/include/google/protobuf/map.h:55, from /usr/local/include/google/protobuf/generated_message_table_driven.h:34, from Imu.pb.h:26, from Imu.pb.cc:4: /usr/local/include/google/protobuf/metadata_lite.h:97:29: note: candidate: template<class T> T* google::protobuf::internal::InternalMetadata::mutable_unknown_fields() PROTOBUF_ALWAYS_INLINE T* mutable_unknown_fields() { ^~~~~~~~~~~~~~~~~~~~~~ /usr/local/include/google/protobuf/metadata_lite.h:97:29: note: template argument deduction/substitution failed: In file included from Imu.pb.h:35:0, from Imu.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/quaternion.pb.h:65:55: note: couldn't deduce template parameter ‘T’ return _internal_metadata_.mutable_unknown_fields(); ^ In file included from Imu.pb.h:36:0, from Imu.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h: At global scope: /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h:149:33: error: ‘InternalMetadataWithArena’ in namespace ‘google::protobuf::internal’ does not name a type ::google::protobuf::internal::InternalMetadataWithArena _internal_metadata_; ^~~~~~~~~~~~~~~~~~~~~~~~~ /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h: In member function ‘const google::protobuf::UnknownFieldSet& gazebo::msgs::Vector3d::unknown_fields() const’: /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h:61:47: error: no matching function for call to ‘google::protobuf::internal::InternalMetadata::unknown_fields() const’ return _internal_metadata_.unknown_fields(); ^ In file included from /usr/local/include/google/protobuf/message_lite.h:49:0, from /usr/local/include/google/protobuf/generated_enum_util.h:36, from /usr/local/include/google/protobuf/map.h:55, from /usr/local/include/google/protobuf/generated_message_table_driven.h:34, from Imu.pb.h:26, from Imu.pb.cc:4: /usr/local/include/google/protobuf/metadata_lite.h:87:35: note: candidate: template<class T> const T& google::protobuf::internal::InternalMetadata::unknown_fields(const T& (*)()) const PROTOBUF_ALWAYS_INLINE const T& unknown_fields( ^~~~~~~~~~~~~~ /usr/local/include/google/protobuf/metadata_lite.h:87:35: note: template argument deduction/substitution failed: In file included from Imu.pb.h:36:0, from Imu.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h:61:47: note: candidate expects 1 argument, 0 provided return _internal_metadata_.unknown_fields(); ^ /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h: In member function ‘google::protobuf::UnknownFieldSet* gazebo::msgs::Vector3d::mutable_unknown_fields()’: /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h:65:55: error: no matching function for call to ‘google::protobuf::internal::InternalMetadata::mutable_unknown_fields()’ return _internal_metadata_.mutable_unknown_fields(); ^ In file included from /usr/local/include/google/protobuf/message_lite.h:49:0, from /usr/local/include/google/protobuf/generated_enum_util.h:36, from /usr/local/include/google/protobuf/map.h:55, from /usr/local/include/google/protobuf/generated_message_table_driven.h:34, from Imu.pb.h:26, from Imu.pb.cc:4: /usr/local/include/google/protobuf/metadata_lite.h:97:29: note: candidate: template<class T> T* google::protobuf::internal::InternalMetadata::mutable_unknown_fields() PROTOBUF_ALWAYS_INLINE T* mutable_unknown_fields() { ^~~~~~~~~~~~~~~~~~~~~~ /usr/local/include/google/protobuf/metadata_lite.h:97:29: note: template argument deduction/substitution failed: In file included from Imu.pb.h:36:0, from Imu.pb.cc:4: /usr/include/gazebo-9/gazebo/msgs/vector3d.pb.h:65:55: note: couldn't deduce template parameter ‘T’ return _internal_metadata_.mutable_unknown_fields(); ^ In file included from Imu.pb.cc:4:0: Imu.pb.h: In member function ‘const gazebo::msgs::Quaternion& sensor_msgs::msgs::Imu::_internal_orientation() const’: Imu.pb.h:397:24: error: ‘_Quaternion_default_instance_’ is not a member of ‘gazebo::msgs’ &::gazebo::msgs::_Quaternion_default_instance_); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Imu.pb.h: In member function ‘const gazebo::msgs::Vector3d& sensor_msgs::msgs::Imu::_internal_angular_velocity() const’: Imu.pb.h:523:24: error: ‘_Vector3d_default_instance_’ is not a member of ‘gazebo::msgs’ &::gazebo::msgs::_Vector3d_default_instance_); ^~~~~~~~~~~~~~~~~~~~~~~~~~~ Imu.pb.h: In member function ‘const gazebo::msgs::Vector3d& sensor_msgs::msgs::Imu::_internal_linear_acceleration() const’: Imu.pb.h:649:24: error: ‘_Vector3d_default_instance_’ is not a member of ‘gazebo::msgs’ &::gazebo::msgs::_Vector3d_default_instance_); ^~~~~~~~~~~~~~~~~~~~~~~~~~~ Imu.pb.cc: At global scope: Imu.pb.cc:17:8: error: ‘PROTOBUF_INTERNAL_EXPORT_quaternion_2eproto’ does not name a type; did you mean ‘PROTOBUF_INTERNAL_EXPORT_Imu_2eproto’? extern PROTOBUF_INTERNAL_EXPORT_quaternion_2eproto ::PROTOBUF_NAMESPACE_ID::internal::SCCInfo<0> scc_info_Quaternion_quaternion_2eproto; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ PROTOBUF_INTERNAL_EXPORT_Imu_2eproto Imu.pb.cc:18:8: error: ‘PROTOBUF_INTERNAL_EXPORT_vector3d_2eproto’ does not name a type; did you mean ‘PROTOBUF_INTERNAL_EXPORT_Imu_2eproto’? extern PROTOBUF_INTERNAL_EXPORT_vector3d_2eproto ::PROTOBUF_NAMESPACE_ID::internal::SCCInfo<0> scc_info_Vector3d_vector3d_2eproto; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ PROTOBUF_INTERNAL_EXPORT_Imu_2eproto Imu.pb.cc:40:8: error: ‘scc_info_Quaternion_quaternion_2eproto’ was not declared in this scope &scc_info_Quaternion_quaternion_2eproto.base, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Imu.pb.cc:41:8: error: ‘scc_info_Vector3d_vector3d_2eproto’ was not declared in this scope &scc_info_Vector3d_vector3d_2eproto.base,}}; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Imu.pb.cc:41:8: note: suggested alternative: ‘scc_info_Imu_Imu_2eproto’ &scc_info_Vector3d_vector3d_2eproto.base,}}; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ scc_info_Imu_Imu_2eproto Imu.pb.cc:91:6: error: ‘::descriptor_table_quaternion_2eproto’ has not been declared &::descriptor_table_quaternion_2eproto, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Imu.pb.cc:91:6: note: suggested alternative: ‘descriptor_table_protodef_Imu_2eproto’ &::descriptor_table_quaternion_2eproto, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ descriptor_table_protodef_Imu_2eproto Imu.pb.cc:92:6: error: ‘::descriptor_table_vector3d_2eproto’ has not been declared &::descriptor_table_vector3d_2eproto, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Imu.pb.cc:92:6: note: suggested alternative: ‘descriptor_table_Imu_2eproto’ &::descriptor_table_vector3d_2eproto, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ descriptor_table_Imu_2eproto Imu.pb.cc: In static member function ‘static void sensor_msgs::msgs::Imu::InitAsDefaultInstance()’: Imu.pb.cc:114:35: error: ‘internal_default_instance’ is not a member of ‘gazebo::msgs::Quaternion’ ::gazebo::msgs::Quaternion::internal_default_instance()); ^~~~~~~~~~~~~~~~~~~~~~~~~ Imu.pb.cc:116:33: error: ‘internal_default_instance’ is not a member of ‘gazebo::msgs::Vector3d’ ::gazebo::msgs::Vector3d::internal_default_instance()); ^~~~~~~~~~~~~~~~~~~~~~~~~ Imu.pb.cc:118:33: error: ‘internal_default_instance’ is not a member of ‘gazebo::msgs::Vector3d’ ::gazebo::msgs::Vector3d::internal_default_instance()); ^~~~~~~~~~~~~~~~~~~~~~~~~ At global scope: cc1plus: warning: unrecognized command line option ‘-Wno-address-of-packed-member’ ninja: build stopped: subcommand failed. FAILED: external/Stamp/sitl_gazebo/sitl_gazebo-build cd /home/sique/src/Firmware/build/px4_sitl_default/build_gazebo && /usr/bin/cmake --build /home/sique/src/Firmware/build/px4_sitl_default/build_gazebo -- -j2 ninja: build stopped: subcommand failed. Makefile:217: recipe for target 'px4_sitl_default' failed make: *** [px4_sitl_default] Error 1
