Trying to operate simple servo px4 qgc
I’m currently trying to connect a servo to test PWM output on AUX1 and nothing seems to work to get any real output to the servo. I have supplied it with 5v power and currently have RC_MAP_AUX1 set to Channel 5. And I have the servo signal wire connected to pin 5 on the output 5 on “main out” (px4 flight controller.
im using airframe “generic quadcopter” (4001).
can anyone point me what im doing wrong please :slight_smile:
I’m aware this is always a bit tricky.
With the latest to be released version, the actuator configuration has improved quite a bit.
So, you could try flash latest beta and then go to the QGC actuators tab to set it up.
thanks julian
is there any link to that beta version or it hasn’t been release ?
When you flash in QGC, you should be able to select beta. Can you try that?
Hi Julian,
thanks for the respond .
when im trying to load beta it only give me the option v1.13.0-rc
Oh ok, so that’s confusing given we should have a v1.14 beta.
In that case, for now, you would have to build yourself from main.
