Hi!
I trying to inject failures (gps off) into system to test failsafes.
In qgc I can stop and run gps:
But I whant do it in auto mode from onbord compute (RPi4)
I tried do it by MAVSDK C++ with Failure plugin.
auto failure = std::make_shared<mavsdk::Failure>(_system);
auto result = failure->inject(mavsdk::Failure::FailureUnit::SensorGps,mavsdk::Failure::FailureType::Off,0);
std::cout << "Result\t" << result << std::endl;
but geted some warnigns and error
[03:15:05|Warn ] sending again after 0.5003 s, retries to do: 3 (420). (mavlink_command_sender.cpp:287)
[03:15:05|Warn ] sending again after 1.00061 s, retries to do: 2 (420). (mavlink_command_sender.cpp:287)
[03:15:06|Warn ] sending again after 1.5092 s, retries to do: 1 (420). (mavlink_command_sender.cpp:287)
[03:15:06|Error] Retrying failed (420) (mavlink_command_sender.cpp:307)
Result Timeout
I tried do it by MAVSDK C++ with Shell plugin
auto shell = std::make_shared<mavsdk::Shell>(_system);
auto result = shell->send("gps stop");
Result Success
But the gps didn’t actually stoped.
Аnyone can help me?
I will be very grateful ![]()
