When trying to run the offboard example indoor, I am stuck in the while loop and the program keeps printing ‘Waiting for system to be ready’. I guess that’s because I don’t have enough GPS satellites, so I tried to change the function that is blocking in MAVSDK/src/mavsdk/plugins/telemetry/telemetry_impl.cpp like this:
bool TelemetryImpl::health_all_ok() const
std::lock_guard<std::mutex> lock(_health_mutex);
if (_health.is_gyrometer_calibration_ok && _health.is_accelerometer_calibration_ok &&
_health.is_magnetometer_calibration_ok /*&& _health.is_local_position_ok &&
_health.is_global_position_ok && _health.is_home_position_ok*/) {
return true;
} else {
return false;
But it appears that the changes are not taking effect after a ‘make’. I thought that maybe some dependencies are not included, so I tried the rebuild the entire MAVSDK with cmake but I am struck with an other issue which I don’t know how to resolve :
[100%] Built target mavlink
-- MAVLink headers for dialect common generated in /home/geyart/projects/MAVSDK/build/third_party/mavlink/mavlink/src/mavlink/include/
-- ccache enabled (export CCACHE_DISABLE=1 to disable)
-- Found curl via config file: /home/geyart/projects/MAVSDK/build/third_party/install/lib/cmake/CURL
CMake Error at src/mavsdk/core/CMakeLists.txt:51 (set_target_properties):
set_target_properties called with incorrect number of arguments.
CMake Error at src/CMakeLists.txt:63 (add_subdirectory):
The source directory
/home/geyart/projects/MAVSDK/src/third_party/gtest
does not contain a CMakeLists.txt file.
-- BUILD_MAVSDK_SERVER not set: not building grpc mavsdk_server
So I would like to know if there is a way to control the drone with MAVSDK indoor without manual control? I want to first try some test indoor (without removing the GPS but just ignoring it) and I am particularly interested in the body frame control offered by the offboard example.
Any help is appreciated.
