- Amax 2312 motor
- Zex 80A ESC
- ark fpv flight contoller
I think I set up the drone for initial flight correctly, but when the arming or motor test slide is set to the minimum, the motor speed is too fast.
Even without raising the throttle during arming, the altitude climbs extremely fast, so I try to disarm it to bring it back down and find a solution, but I don’t know what to do, so I’m asking for help.
Take the propellers off before any more arming or motor-test work. If the aircraft already climbs at minimum throttle, the armed idle is above hover thrust, and that is unsafe to keep testing with props on.
In QGroundControl, open Vehicle Setup → Actuators and do the checks there, with props off:
Confirm the airframe type is correct and each motor is assigned to the expected output. Also confirm the output protocol matches the ESCs (PWM, OneShot, or DShot). A protocol mismatch can make “minimum” look like a much higher throttle.
If the ESCs are PWM or OneShot, run ESC Calibration first (QGC Power page). Keep the flight controller powered over USB, unplug the battery so the ESCs are unpowered until QGC prompts you to power them, and never do this with propellers installed. After a successful calibration, the usual motor defaults are about 1000 µs disarmed, 1100 µs minimum, and 1900 µs maximum.
In Actuator Testing, the slider’s bottom snap is the disarmed value — motors should be fully stopped. If they still spin, lower that disarmed value. The first snap up is the minimum value — motors should just barely, but reliably, spin. If they are already spinning hard, lower the Minimum value for those motor outputs until they only tick over. For DShot, you generally do not tune those PWM limits the same way; check that the protocol is actually set to DShot, then confirm idle is still only a slow spin.
Recalibrate the RC throttle so the stick at the bottom is truly zero, and do the first later hover attempt in Stabilized (not Altitude or Position). A high throttle endpoint, or a position-controlled mode with a bad hover-thrust estimate, can also make the vehicle climb as soon as it arms.
An 80 A ESC on 2312-class motors is oversized, but that alone should not cause a fast climb at idle. A calibration or protocol mismatch is the more likely cause. Don’t put the props back on until the minimum slider only produces a slow idle, and you can see that hover would take a clear increase in throttle.
Useful references:
If you can share the output protocol, PX4 version, and a screenshot of the Actuators page (disarmed / min / max), we can narrow it down further.
Hi Andrew,
Thanks for confirming the DShot configuration, RC input and motor mapping.
Since the motors begin spinning at around 10% on the Actuator Testing slider but already seem excessively fast, I would avoid further tests with propellers installed until the cause is understood.
One important distinction: the QGroundControl actuator slider percentage is not a direct measurement of motor RPM or hover thrust.
Could you share a few additional details?
PX4 version and flight controller model.
ESC manufacturer, model and firmware (for example, AM32 or BLHeli_32).
Motor model, battery cell count and propeller specifications.
A screenshot of the QGC Actuators output configuration, including the DShot output assignment.
Whether the excessive speed occurs during actuator testing with propellers removed, immediately after arming, or both.
I would also distinguish the motor-test behavior from the flight-controller output during arming, since these follow different control paths.
With those details, we can narrow down whether this is ESC minimum-speed behavior, an output configuration issue or an unexpected PX4 control command.
Please keep the propellers removed during further bench diagnostics.
Best regards,
Yiğitcan Öztürk
PAMILANGA Ltd.
Since DShot is confirmed, don’t use PWM/OneShot ESC calibration as the next step. With props off, lower PX4’s DShot minimum throttle (DSHOT_MIN_THROTTLE in recent builds) or the ESC’s startup/idle setting one step at a time until the first Actuator Testing notch only just starts the motor. If QGC still commands a high value at about 10%, compare that output in a DShot ESC configurator to tell whether PX4 or the ESC is setting the high idle. If it only climbs fast after arming with props, treat that as an arming-idle/thrust issue, not the slider.
