Hello
I am using a dual system, Ubuntu version 18.04, QGC version 4.1 4.2. I want to try to burn the firmware into Pixhawk6c, but it keeps prompting the following error. I am not using a virtual machine. Do you know what the reason is?
Error as follow↓
【## Found device: Pixhawk
Error: Get Board Info: Sync: Send Command: Get Command Response: Timeout waiting for bytes to be available
Upgrade cancelled
If upgrade failed, make sure to connect directly to a powered USB port on your computer, not through a USB hub. Also make sure you are only powered via USB not battery.】
I also encountered the same issue, but I run on VMware. When using the command ‘make px4_fmu-v6xrt_default upload’ to download firmware, it will get stuck in ‘waiting for bootloader’.
