I am using mavsdk python to provide offboard velocity commands and mocap position updates. This is working well, but while running the script at random times my subscriptions to the telemetry plugin often just stop. Below is my code.
#!/usr/bin/env python3
import asyncio
from mavsdk import System
from mavsdk.offboard import (OffboardError, VelocityNedYaw)
from mavsdk.mocap import (AttitudePositionMocap,VisionPositionEstimate,Quaternion,PositionBody,AngleBody,Covariance)
from mavsdk.telemetry import FlightMode
import navpy
import rospy
import numpy as np
from nav_msgs.msg import Odometry
from geometry_msgs.msg import Point
from geometry_msgs.msg import PoseWithCovarianceStamped
from std_msgs.msg import Bool
class CntrlPx4:
def __init__(self):
self.velCmd = [0.0,0.0,0.0]
self.prevPoseTime = 0.0
self.estimateMsg = Odometry()
self.meas1_received = False
self.flightMode = 'none'
self.offBoardOn = False
self.sim = rospy.get_param('~sim', False)
self.systemAddress = rospy.get_param('~systemAddress', "serial:///dev/ttyUSB0:921600")
self.estimate_pub_ = rospy.Publisher('estimate',Odometry,queue_size=5,latch=True)
self.switch_integrators_pub_ = rospy.Publisher('switch_integrators',Bool,queue_size=5,latch=True)
self.vel_cmd_sub_ = rospy.Subscriber('velCmd', Point, self.velCmdCallback, queue_size=5)
self.positiion_measurement_sub_ = rospy.Subscriber('position_measurement', PoseWithCovarianceStamped, self.positionMeasurementCallback, queue_size=5)
def velCmdCallback(self,msg):
self.velCmd = [msg.x,msg.y,msg.z]
def positionMeasurementCallback(self,msg):
time = np.array(msg.header.stamp.secs) + np.array(msg.header.stamp.nsecs*1E-9) #TODO this prossibly needs to be adjusted for the px4 time.
time = int(round(time,6)*1E6)
angleBody = AngleBody(0.0,0.0,0.0) #Currently no angle information is given
positionBody = PositionBody(msg.pose.pose.position.x,msg.pose.pose.position.y,msg.pose.pose.position.z)
covarianceMatrix = self.convert_ros_covariance_to_px4_covariance(msg.pose.covariance)
poseCovariance = Covariance(covarianceMatrix)
self.pose = VisionPositionEstimate(time,positionBody,angleBody,poseCovariance)
self.meas1_received = True
def convert_ros_covariance_to_px4_covariance(self,rosCov):
px4Cov = [0]*21
px4Cov[0:6] = rosCov[0:6]
px4Cov[6:11] = rosCov[7:12]
px4Cov[11:15] = rosCov[14:18]
px4Cov[15:18] = rosCov[21:24]
px4Cov[18:20] = rosCov[28:30]
px4Cov[20] = rosCov[35]
return px4Cov
def publish_estimate(self,odom):
time = odom.time_usec*1E-6
secs = int(time)
nsecs = int((time-secs)*1E9)
self.estimateMsg.header.stamp.secs = secs
self.estimateMsg.header.stamp.nsecs = nsecs
self.estimateMsg.pose.pose.position.x = odom.position_body.x_m
self.estimateMsg.pose.pose.position.y = odom.position_body.y_m
self.estimateMsg.pose.pose.position.z = odom.position_body.z_m
self.estimateMsg.pose.pose.orientation.x = odom.q.x
self.estimateMsg.pose.pose.orientation.y = odom.q.y
self.estimateMsg.pose.pose.orientation.z = odom.q.z
self.estimateMsg.pose.pose.orientation.w = odom.q.w
self.estimateMsg.pose.covariance = self.convert_px4_covariance_to_ros_covariance(odom.pose_covariance.covariance_matrix)
self.estimateMsg.twist.twist.linear.x = odom.velocity_body.x_m_s
self.estimateMsg.twist.twist.linear.y = odom.velocity_body.y_m_s
self.estimateMsg.twist.twist.linear.z = odom.velocity_body.z_m_s
self.estimateMsg.twist.twist.angular.x = odom.angular_velocity_body.roll_rad_s
self.estimateMsg.twist.twist.angular.y = odom.angular_velocity_body.pitch_rad_s
self.estimateMsg.twist.twist.angular.z = odom.angular_velocity_body.yaw_rad_s
self.estimateMsg.twist.covariance = self.convert_px4_covariance_to_ros_covariance(odom.velocity_covariance.covariance_matrix)
self.estimate_pub_.publish(self.estimateMsg)
def convert_px4_covariance_to_ros_covariance(self,px4Cov):
rosCov = [0]*36
rosCov[0:6] = px4Cov[0:6]
rosCov[7:12] = px4Cov[6:11]
rosCov[14:18] = px4Cov[11:15]
rosCov[21:24] = px4Cov[15:18]
rosCov[28:30] = px4Cov[18:20]
rosCov[35] = px4Cov[20]
return rosCov
def switch_integrators(self,onOffFlag):
flag = Bool()
flag.data = onOffFlag
self.switch_integrators_pub_.publish(flag)
async def run(self):
""" Does Offboard control using velocity NED coordinates. """
self.drone = System()
await self.drone.connect(system_address=self.systemAddress)
print("Waiting for drone to connect...")
await asyncio.sleep(5)
async for state in self.drone.core.connection_state():
if state.is_connected:
print(f"Drone discovered with UUID: {state.uuid}")
break
print("Start updating position")
# 100 hz seems to be the max odom rate.
asyncio.create_task(self.get_status())
await self.drone.telemetry.set_rate_odometry(100)
await asyncio.sleep(2)
asyncio.create_task(self.input_meas_output_est())
if self.sim == True:
await self.drone.action.arm()
await self.drone.offboard.set_velocity_ned(VelocityNedYaw(0.0, 0.0, 0.0, 0.0))
await self.drone.offboard.start()
print("Simulation starting offboard.")
await asyncio.gather(self.get_status(),self.input_meas_output_est(),self.flight_modes())
async def flight_modes(self):
async for flight_mode in self.drone.telemetry.flight_mode():
if self.flightMode != flight_mode:
print("FlightMode:", flight_mode)
self.flightMode = flight_mode
if flight_mode == FlightMode(7):
self.switch_integrators(True)
self.offBoardOn = True
else:
self.switch_integrators(False)
async def input_meas_output_est(self):
async for odom in self.drone.telemetry.odometry():
self.publish_estimate(odom)
if self.pose.time_usec != self.prevPoseTime and self.meas1_received:
await self.drone.mocap.set_vision_position_estimate(self.pose)
self.prevPoseTime = self.pose.time_usec
await self.drone.offboard.set_velocity_ned(VelocityNedYaw(self.velCmd[0],self.velCmd[1],self.velCmd[2],0.0))
async def get_status(self):
async for status in self.drone.telemetry.status_text():
print(status.type, status.text)
if __name__ == "__main__":
rospy.init_node('control_px4', anonymous=True)
try:
cntrl_px4 = CntrlPx4()
loop = asyncio.get_event_loop()
loop.run_until_complete(cntrl_px4.run())
loop.run_forever()
except:
rospy.ROSInterruptException
pass
As you can see, I am using ros to communicate with other nodes, but the asyncio run function is what I use to communicate with px4. Randomly, async for flight_mode in self.drone.telemetry.flight_mode(): and async for odom in self.drone.telemetry.odometry(): stop doing anything. I have checked and the telemetry plugin is no longer providing any information when this happens. Below are the logged messages.
The logged messages show that the velocity estimates are reset to zero and that navigation is stopped, but I am not sure why.
Any help, suggestions, or insight would be very much appreciated.
