After I have clicked on a button or a slider in QGC if I press spacebar the click-acion is repeated. This potentially can be dangerous if your laptop have gone “dark screen” and you have reactivated it by pressing a spacebar key.
I was trying for an embarrasing amount of time to find where in the code this strange logic is implemented but could not find it.
I would greatly appreciate any help with this matter.
Hi, After I have clicked on a button or a slider in QGC if I press spacebar the click-acion is repeated. This potentially can be dangerous … First, check for dirt that is blocking the keys or sensor, then run the *keyboard troubleshooter: Go to Start causing the keyboard to Spacebar clicker repeat those keys. Other times the keys may release back to their normal position, but the circuit board in the keyboard may be sticking, causing the keys to be repeated.
