Hello there,
how do I add a range finder sensor like a sonar, IR sensor or a laser to the iris copter?
I’ve been able to add a camera by adding a xacro:camera_macro section to iris_base.xacro, but there does not seem to be a macro for any distance measurement sensor.
Docs about simulation with gazebo mention make posix gazebo_iris_opt_flow, which I figure could enable the px4flow sonar, but I need to start the simulation with MAVROS capabilities, i.e. roslaunch px4 mavros_posix_sitl.launch.
Any help is appreciated.
Thanks.
OK, so I figured it out in the end, but it was very hard and I don’t feel like my solution is perfect.
It is a pity there doesn’t seem to be any documentation on that subject.
In order to edit the simulated sensors, I ended up creating a new vehicle and a new launch file spawning that particular vehicle instead of the default IRIS.
In the launch directory, create a new file called mavros_posix_sitl_sonar.launch containing:
<?xml version="1.0"?> <launch> <include file="$(find px4)/launch/mavros_posix_sitl.launch"> <arg name="vehicle" value="iris_sonar"/> </include> </launch>
This does all the stuff from mavros_posix_sitl.launch, but overrides the vehicle to be iris_sonar. This vehicle doesn’t exist yet, so create it:
In Tools/sitl_gazebo/models create a new folder iris_sonar with a model.config file corresponding to the ones in the other model folders and a iris_sonar.sdf file containing:
<sdf version='1.5'>
<model name='iris_odom'>
<include>
<uri>model://iris</uri>
</include>
<!--sonar-->
<link name="range_down_link">
<pose frame=''>0 0.015 -0.04 3.14159 1.57079 3.14159</pose>
<inertial> <!-- causes issues when omitted -->
<mass>0.05</mass>
<inertia>
<ixx>2.08333333333e-07</ixx>
<iyy>5.20833333333e-07</iyy>
<izz>5.20833333333e-07</izz>
</inertia>
</inertial>
<visual name="range_down_link_visual">
<pose frame=''>0 0 0 0 1.57079 0</pose>
<geometry>
<cylinder>
<length>0.008</length>
<radius>0.004</radius>
</cylinder>
</geometry>
<material>
<script>
<name>Gazebo/Blue</name>
<uri>file://media/materials/scripts/gazebo.material</uri>
</script>
</material>
</visual>
<sensor type="ray" name="iris_range_down">
<update_rate>10</update_rate>
<visualize>true</visualize>
<ray>
<scan>
<horizontal>
<samples>1</samples>
<resolution>1</resolution>
<min_angle>-0</min_angle>
<max_angle>0</max_angle>
</horizontal>
</scan>
<range>
<min>0.06</min> <!-- do not change (smaller values cause issues) -->
<max>35</max> <!-- do not change (bigger values cause issues) -->
<resolution>0.01</resolution>
</range>
<noise>
<type>gaussian</type>
<mean>0.0</mean>
<stddev>0.01</stddev>
</noise>
</ray>
<plugin name="iris_range_down_controller" filename="libgazebo_ros_range.so">
<robotNamespace>iris_odom</robotNamespace>
<gaussianNoise>0.005</gaussianNoise>
<alwaysOn>true</alwaysOn>
<updateRate>10</updateRate>
<topicName>range_down</topicName>
<frameName>range_down_link</frameName>
<fov>0</fov>
<radiation>ultrasound</radiation>
</plugin>
</sensor>
</link>
<joint name="range_down_joint" type="fixed">
<parent>iris::base_link</parent>
<child>range_down_link</child>
</joint>
</model>
</sdf>
duplicate posix-configs/SITL/init/ekf2/iris and name it iris_sonar
I think that’s all.
By the way, in the MAVLINK shell (which is spawned in the very same terminal in which you start the mavros_posix_sitl.launch or mavros_posix_sitl_sonar.launch respectively) you can type
list_topics
and will probably already have multiple instances of distance_sensor without adding it manually, but these are not published as a ROS topic.
