SIYI A8 in non SIYI QGC
I have the Siyi A8 setup through the herelink ethernet port and have utilized the SIYI QGC thus far. I would like to use the standard QGC to keep the most up to date firmware/software combination. Using the same settings from the SIYI QGC app, the video feed comes through as a black screen. Is there something I am missing or is it not compatible via Ethernet and I have to feed the HDMI in?
Did you find a solution? I also have the same question
