I need to trigger an external device (killswitch of a “companion” computer) via a switch on the remote controller. For this i figured using the camera trigger functionality might work, however I can’t fully figure out how to do this and the only related issue I could find remains unsolved (Camera trigger by RC Channel). I am using the newest 1.14.3 version of PX4-Autopilot on a Cubepilot Cube Orange and set the following parameters:
RC_MAP_AUX5 = Channel 7
PWM_AUX_FUNC5 = Camera Trigger
TRIG_MODE = Time based, on command
TRIG_INTERFACE = GPIO
TRIG_ACT_TIME = 1000.0 ms
TRIG_POLARITY = Active low
I assumed that this would create the functionality, that the channel 7 on the RC can now start the camera trigger, but this does not work. Using the built-in NuttX function camera_trigger test the trigger is done correctly and the signal is output on AUX5.
Is there any issue with my parameters or is this functionality not even intended? Are there any alternatives to set a GPIO pin using the RC?
Thanks for your help,
Andreas
