I also did the same thing as Rakmo97 and got the same error.
PX4: 1.13.3
Mavsdk Python: 1.4.8
In addition for debugging, I ran the mavsdk server on a seperate terminal and it seg faulted when I run the set_actuator_control. It does not seg fault when I replace it with another function like:
await drone.offboard.set_velocity_body(VelocityBodyYawspeed(0.0, 0.0, 0.0, 4))
Code:
import asyncio
from mavsdk import System
from mavsdk.offboard import (ActuatorControl, ActuatorControlGroup, OffboardError)
async def run():
drone = System()
await drone.connect(system_address="udp://:14540")
print("Waiting for drone to connect...")
async for state in drone.core.connection_state():
if state.is_connected:
print(f"-- Connected to drone!")
break
print("Waiting for drone to have a global position estimate...")
async for health in drone.telemetry.health():
if health.is_global_position_ok and health.is_home_position_ok:
print("-- Global position estimate OK")
break
print("-- Arming")
await drone.action.arm()
print("-- Setting initial setpoint")
await drone.offboard.set_actuator_control(ActuatorControl([ActuatorControlGroup([0,0,0,0,0,0,0,0])]))
print("-- Starting offboard")
try:
await drone.offboard.start()
except OffboardError as error:
print(f"Starting offboard mode failed with error code: \
{error._result.result}")
print("-- Disarming")
await drone.action.disarm()
return
print("-- Stopping offboard")
try:
await drone.offboard.stop()
print(f"Stopping offboard mode failed with error code: \
await drone.action.land()
if __name__ == "__main__":
# Run the asyncio loop
asyncio.run(run())
Code Terminal Output:
-- Arming
File "/home/nicholas/MAVSDK-Python/examples/offboard_actuator.py", line 50, in <module>
asyncio.run(run())
File "/usr/lib/python3.10/asyncio/runners.py", line 44, in run
return loop.run_until_complete(main)
File "/usr/lib/python3.10/asyncio/base_events.py", line 649, in run_until_complete
return future.result()
File "/home/nicholas/MAVSDK-Python/examples/offboard_actuator.py", line 27, in run
File "/home/nicholas/.local/lib/python3.10/site-packages/mavsdk/offboard.py", line 1250, in set_actuator_control
response = await self._stub.SetActuatorControl(request)
File "/home/nicholas/.local/lib/python3.10/site-packages/aiogrpc/channel.py", line 40, in __call__
return await fut
grpc._channel._MultiThreadedRendezvous: <_MultiThreadedRendezvous of RPC that terminated with:
status = StatusCode.UNAVAILABLE
details = "Socket closed"
debug_error_string = "UNKNOWN:Error received from peer {created_time:"2023-09-19T17:25:51.247091854+08:00", grpc_status:14, grpc_message:"Socket closed"}"
Server Output:
[02:57:56|Info ] MAVSDK version: v1.4.16 (mavsdk_impl.cpp:20)
[02:57:56|Info ] Waiting to discover system on udp://:14445... (connection_initiator.h:20)
[02:57:56|Info ] New system on: 127.0.0.1:14550 (with sysid: 1) (udp_connection.cpp:192)
[02:57:56|Debug] New: System ID: 1 Comp ID: 1 (mavsdk_impl.cpp:496)
[02:57:56|Debug] Component Autopilot (1) added. (system_impl.cpp:377)
[02:57:57|Warn ] Vehicle type changed (new type: 2, old type: 0) (system_impl.cpp:225)
[02:57:57|Debug] Discovered 1 component(s) (system_impl.cpp:578)
[02:57:57|Info ] System discovered (connection_initiator.h:63)
[02:57:57|Debug] New: System ID: 245 Comp ID: 190 (mavsdk_impl.cpp:496)
[02:57:57|Debug] Component Unsupported component (190) added. (system_impl.cpp:377)
[02:57:57|Info ] Server started (grpc_server.cpp:53)
[02:57:57|Info ] Server set to listen on 0.0.0.0:50051 (grpc_server.cpp:54)
[02:57:57|Debug] Component Unsupported component (240) added. (system_impl.cpp:377)
[02:58:04|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:58:14|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:58:24|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:58:34|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:58:44|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:58:45|Debug] Request Param CAL_GYRO0_ID (mavlink_parameters.cpp:1442)
[02:58:45|Debug] Missing Param CAL_GYRO0_ID (mavlink_parameters.cpp:1452)
[02:58:45|Debug] Request Param CAL_ACC0_ID (mavlink_parameters.cpp:1442)
[02:58:45|Debug] Missing Param CAL_ACC0_ID (mavlink_parameters.cpp:1452)
[02:58:45|Debug] Request Param CAL_MAG0_ID (mavlink_parameters.cpp:1442)
[02:58:45|Debug] Missing Param CAL_MAG0_ID (mavlink_parameters.cpp:1452)
[02:58:46|Debug] Request Param SYS_HITL (mavlink_parameters.cpp:1442)
[02:58:46|Debug] Missing Param SYS_HITL (mavlink_parameters.cpp:1452)
[02:58:54|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:59:04|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:59:14|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:59:24|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:59:34|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:59:44|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[02:59:54|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[03:00:04|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[03:00:14|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[03:00:24|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[03:00:34|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[03:00:44|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
[03:00:54|Warn ] Ignoring unknown ping sequence (ping.cpp:58)
Segmentation fault (core dumped)
