If I run script run-docker.sh I’ve got following error:
./run-docker.sh make BUILD_BACKEND=1 default
Starting with UID : 1000
/bin/su: option requires an argument -- 'c'
Usage: su [options] [LOGIN]
it looks like the script is not passing command line arguments to docker image. I have a fix but I don’t know how the contribution flow (fork github repo and ask for pull request?) so I’m providing the patch here just in case:
diff --git a/run-docker.sh b/run-docker.sh
index 28790cb..0704e66 100755
--- a/run-docker.sh
+++ b/run-docker.sh
@@ -1,3 +1,3 @@
#!/usr/bin/env sh
-docker run -it --rm -v $(pwd):/home/dronecode/DronecodeSDK -e LOCAL_USER_ID=`id -u` dronecode/dronecode-sdk-ubuntu-18.04
+docker run -it --rm -v $(pwd):/home/dronecode/DronecodeSDK -e LOCAL_USER_ID=`id -u` dronecode/dronecode-sdk-ubuntu-18.04 "$@"
And once the patch is applied, there’s another issue I guess I’ll address in a separate post since itś related to the docker image itself
./run-docker.sh make BUILD_BACKEND=1 default Starting with UID : 1000 make: *** No targets specified and no makefile found. Stop.
