Rotors stop spinning in PX4 SITL simulation in Gazebo for custom model
Hi
I am simulating a Custom SITL model in PX4-Autopilot. I git clone https://github.com/PX4/PX4-Autopilot.git in my Linux computer (Ubuntu 20.04 with ROS Noetic).
I follow the instructions here to model a custom model in the SITL software (link: https://discuss.px4.io/t/create-custom-model-for-sitl/6700).
I create the hexaflat.sdf, hexaflat.world, model.config based on the typhon_h480 model available in the PX4 GitHub. Also, I create the airframe file 3012_hexaflat based on the tyhpoon_h480 as well.
I am able to run the simulation in gazebo with: make px4_sitl gazebo_hexaflat and the model appears in the simulator. When I input the command in the px4 terminal commander takeoff the model starts lifting, but some motors stop spinning. The model tilts and falls over.
Is like the same issue in this post:PX4-SITL with custom URDF model, drone crash after take off but I am using an sdf file.
I do not know why it is happening since I copy the typhoon files and I am able to fly the Typhoon model with commander takeoff.
I also add the hexaflat.sdf file.
<!-- DO NOT EDIT: Generated from iris.sdf.jinja -->
<sdf version='1.6'>
  <model name='hexaflat'>
    <link name='base_link'>
      <pose>0 0 0 0 0 0</pose>
      <inertial>
        <pose>0.001005 0 -0.0090035 0 0 0</pose>
        <mass>1.7971</mass>
        <inertia>
          <ixx>0.0244</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.0422</iyy>
          <iyz>0</iyz>
          <izz>0.0235</izz>
        </inertia>
      </inertial>
      <collision name='base_link_collision'>
        <pose>0 0 0.0 0 0 0</pose>
        <geometry>
          <box>
            <size>0.6 0.6 0.38</size>
          </box>
        </geometry>
        <surface>
          <contact>
            <ode>
              <min_depth>0.001</min_depth>
              <max_vel>0</max_vel>
            </ode>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
      <visual name='base_link_visual'>
        <geometry>
          <mesh>
            <scale>1 1 1</scale>
            <uri>model://hexaflat/meshes/base_link.stl</uri>
          </mesh>
        </geometry>
        <material>
          <script>
            <name>Gazebo/DarkGrey</name>
            <uri>file://media/materials/scripts/gazebo.material</uri>
          </script>
        </material>
      </visual>
      <gravity>1</gravity>
      <velocity_decay/>
      <self_collide>0</self_collide>
    </link>
    <include>
      <uri>model://imu</uri>
      <pose relative_to='base_link'>0 0 0.125 0 0 0</pose>
      <name>imu</name>
    </include>
    <joint name='imu_joint' type='revolute'>
      <child>imu::link</child>
      <parent>base_link</parent>
      <axis>
        <xyz>1 0 0</xyz>
        <limit>
          <lower>0</lower>
          <upper>0</upper>
          <effort>0</effort>
          <velocity>0</velocity>
        </limit>
        <dynamics>
          <spring_reference>0</spring_reference>
          <spring_stiffness>0</spring_stiffness>
        </dynamics>
        <use_parent_model_frame>1</use_parent_model_frame>
      </axis>
    </joint>
    <link name='rotor_3'>
      <pose >0.13 -0.22 0.0325 0 0 0</pose>
      <inertial>
        <mass>0.007</mass>
        <inertia>
          <ixx>0.000014</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.000014</iyy>
          <iyz>0</iyz>
          <izz>0</izz>
        </inertia>
      </inertial>
      <collision name='rotor_3_collision'>
        <geometry>
          <cylinder>
            <length>0.005</length>
            <radius>0.128</radius>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
      <visual name='rotor_3_visual'>
        <pose relative_to='rotor_3'>0 -0.1016 0 0 0 0</pose>
        <geometry>
          <mesh>
            <scale>0.0009 0.0009 0.0009</scale>
            <uri>model://hexaflat/meshes/prop_ccw_hexaflat.stl</uri>
          </mesh>
        </geometry>
        <material>
          <script>
            <name>Gazebo/Green</name>
          </script>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name='rotor_3_joint' type='revolute'>
      <child>rotor_3</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
          <lower>-1e+16</lower>
          <upper>1e+16</upper>
          <effort>10</effort>
          <velocity>-1</velocity>
        </limit>
        <dynamics>
          <damping>0.005</damping>
        </dynamics>
      </axis>
      <physics>
        <ode>
          <implicit_spring_damper>1</implicit_spring_damper>
        </ode>
      </physics>
    </joint>
    <link name='rotor_0'>
      <pose>0.25 0 0.0325 0 0 0</pose>
      <inertial>
        <mass>0.007</mass>
        <inertia>
          <ixx>0.000014</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.000014</iyy>
          <iyz>0</iyz>
          <izz>0</izz>
        </inertia>
      </inertial>
      <collision name='rotor_0_collision'>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
      <visual name='rotor_0_visual'>
        <pose>0 -0.1016 0 0 0 0</pose>
        <geometry>
          <mesh>
            <uri>model://hexaflat/meshes/prop_cw_hexaflat.stl</uri>
          </mesh>
        </geometry>
        <material>
          <script>
            <name>Gazebo/Orange</name>
          </script>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name='rotor_0_joint' type='revolute'>
      <pose relative_to='rotor_0'>0 0 0 0 0 0</pose>
      <child>rotor_0</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
          <effort>10</effort>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name='rotor_4'>
      <pose>0.13 0.22 0.0325 0 0 0</pose>
      <inertial>
        <mass>0.007</mass>
        <inertia>
          <ixx>0.000014</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.000014</iyy>
          <iyz>0</iyz>
          <izz>0</izz>
        </inertia>
      </inertial>
      <collision name='rotor_4_collision'>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
      <visual name='rotor_4_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <script>
            <name>Gazebo/Red</name>
          </script>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name='rotor_4_joint' type='revolute'>
      <pose relative_to='rotor_4'>0 0 0 0 0 0</pose>
      <child>rotor_4</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
          <effort>10</effort>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name='rotor_1'>
      <pose>-0.25 0 0.0325 0 0 0</pose>
      <inertial>
        <mass>0.007</mass>
        <inertia>
          <ixx>0.000014</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.000014</iyy>
          <iyz>0</iyz>
          <izz>0</izz>
        </inertia>
      </inertial>
      <collision name='rotor_1_collision'>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
      <visual name='rotor_1_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <script>
            <name>Gazebo/Purple</name>
          </script>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name='rotor_1_joint' type='revolute'>
      <pose relative_to='rotor_1'>0 0 0 0 0 0</pose>
      <child>rotor_1</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
          <effort>10</effort>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name='rotor_5'>
      <pose>-0.13 -0.22 0.0325 0 0 0.75</pose>
      <inertial>
        <mass>0.007</mass>
        <inertia>
          <ixx>0.000014</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.000014</iyy>
          <iyz>0</iyz>
          <izz>0</izz>
        </inertia>
      </inertial>
      <collision name='rotor_5_collision'>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
      <visual name='rotor_5_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <script>
            <name>Gazebo/White</name>
          </script>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name='rotor_5_joint' type='revolute'>
      <pose relative_to='rotor_5'>0 0 0 0 0 0</pose>
      <child>rotor_5</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
          <effort>10</effort>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name='rotor_2'>
      <pose >-0.13 0.22 0.0325 0 0 0</pose>
      <inertial>
        <mass>0.007</mass>
        <inertia>
          <ixx>0.000014</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.000014</iyy>
          <iyz>0</iyz>
          <izz>0</izz>
        </inertia>
      </inertial>
      <collision name='rotor_2_collision'>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
      <visual name='rotor_2_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <script>
            <name>Gazebo/Yellow</name>
          </script>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name='rotor_2_joint' type='revolute'>
      <pose relative_to='rotor_2'>0 0 0 0 0 0</pose>
      <child>rotor_2</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
          <effort>10</effort>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <include>
      <uri>model://gps</uri>
      <pose relative_to='base_link'>0.1 0 0.075 0 0 0</pose>
      <name>gps</name>
    </include>
    <joint name='gps_joint' type='fixed'>
      <child>gps::link</child>
    </joint>
    <include>
      <uri>model://magnetometer</uri>
      <pose relative_to='base_link'>0 0.1 0.075 0 0 0</pose>
      <name>mag</name>
    </include>
    <joint name='mag_joint' type='fixed'>
      <child>mag::link</child>
    </joint>
    <plugin name='rosbag' filename='libgazebo_multirotor_base_plugin.so'>
      <robotNamespace></robotNamespace>
      <linkName>base_link</linkName>
      <rotorVelocitySlowdownSim>10</rotorVelocitySlowdownSim>
    </plugin>
    <plugin name='front_right_motor_model' filename='libgazebo_motor_model.so'>
      <jointName>rotor_0_joint</jointName>
      <linkName>rotor_0</linkName>
      <turningDirection>cw</turningDirection>
      <timeConstantUp>0.0125</timeConstantUp>
      <timeConstantDown>0.025</timeConstantDown>
      <maxRotVelocity>1500</maxRotVelocity>
      <motorConstant>8.54858e-06</motorConstant>
      <momentConstant>0.06</momentConstant>
      <commandSubTopic>/gazebo/command/motor_speed</commandSubTopic>
      <motorNumber>0</motorNumber>
      <rotorDragCoefficient>0.000806428</rotorDragCoefficient>
      <rollingMomentCoefficient>1e-06</rollingMomentCoefficient>
      <motorSpeedPubTopic>/motor_speed/0</motorSpeedPubTopic>
    </plugin>
    <plugin name='front_left_motor_model' filename='libgazebo_motor_model.so'>
      <jointName>rotor_1_joint</jointName>
      <linkName>rotor_1</linkName>
      <turningDirection>ccw</turningDirection>
      <motorNumber>1</motorNumber>
      <motorSpeedPubTopic>/motor_speed/1</motorSpeedPubTopic>
    </plugin>
      <jointName>rotor_2_joint</jointName>
      <linkName>rotor_2</linkName>
      <motorNumber>2</motorNumber>
      <motorSpeedPubTopic>/motor_speed/2</motorSpeedPubTopic>
    </plugin>
    <plugin name='back_right_motor_model' filename='libgazebo_motor_model.so'>
      <jointName>rotor_3_joint</jointName>
      <linkName>rotor_3</linkName>
      <motorNumber>3</motorNumber>
      <motorSpeedPubTopic>/motor_speed/3</motorSpeedPubTopic>
    </plugin>
      <jointName>rotor_4_joint</jointName>
      <linkName>rotor_4</linkName>
      <motorNumber>4</motorNumber>
      <motorSpeedPubTopic>/motor_speed/4</motorSpeedPubTopic>
    </plugin>
    <plugin name='back_left_motor_model' filename='libgazebo_motor_model.so'>
      <jointName>rotor_5_joint</jointName>
      <linkName>rotor_5</linkName>
      <motorNumber>5</motorNumber>
      <motorSpeedPubTopic>/motor_speed/5</motorSpeedPubTopic>
    </plugin>
    <plugin name='groundtruth_plugin' filename='libgazebo_groundtruth_plugin.so'>
      <robotNamespace/>
    </plugin>
    <plugin name='barometer_plugin' filename='libgazebo_barometer_plugin.so'>
      <robotNamespace/>
      <pubRate>50</pubRate>
      <baroTopic>/baro</baroTopic>
    </plugin>
    <plugin name='mavlink_interface' filename='libgazebo_mavlink_interface.so'>
      <imuSubTopic>/imu</imuSubTopic>
      <magSubTopic>/mag</magSubTopic>
      <baroSubTopic>/baro</baroSubTopic>
      <mavlink_addr>INADDR_ANY</mavlink_addr>
      <mavlink_tcp_port>4560</mavlink_tcp_port>
      <mavlink_udp_port>14560</mavlink_udp_port>
      <serialEnabled>0</serialEnabled>
      <serialDevice>/dev/ttyACM0</serialDevice>
      <baudRate>921600</baudRate>
      <qgc_addr>INADDR_ANY</qgc_addr>
      <qgc_udp_port>14550</qgc_udp_port>
      <sdk_addr>INADDR_ANY</sdk_addr>
      <sdk_udp_port>14540</sdk_udp_port>
      <hil_mode>0</hil_mode>
      <hil_state_level>false</hil_state_level>
      <enable_lockstep>true</enable_lockstep>
      <use_tcp>true</use_tcp>
      <motorSpeedCommandPubTopic>/gazebo/command/motor_speed</motorSpeedCommandPubTopic>
      <control_channels>
        <channel name="rotor0">
          <input_index>0</input_index>
          <input_offset>0</input_offset>
          <input_scaling>1500</input_scaling>
          <zero_position_disarmed>0</zero_position_disarmed>
          <zero_position_armed>100</zero_position_armed>
          <joint_control_type>velocity</joint_control_type>
        </channel>
        <channel name="rotor1">
          <input_index>1</input_index>
        </channel>
        <channel name="rotor2">
          <input_index>2</input_index>
        </channel>
        <channel name="rotor3">
          <input_index>3</input_index>
        </channel>
        <channel name="rotor4">
          <input_index>4</input_index>
        </channel>
       <channel name="rotor5">
          <input_index>5</input_index>
        </channel>
      </control_channels>
    </plugin>
    <static>0</static>
  </model>
</sdf>
Can you guide on how to debug this sdf file or where is the problem here?
Thanks in advance!
Adán Márquez
I’m facing the same problem—one of the six rotors isn’t working. Could anyone provide some advice?
