Hi all.
I am planning to run a fixed-wing plane with PX4.
However, I plan to use it for some autonomous research, where I need to:
- Send velocity commands / way-points continuously
- Send sensor data (LiDar / Intel Realsense) for mapping to an external computer.
Essentially I am planning to use a custom path-planning algorithm that performs some obstacle avoidance, as well as precision landing on a moving target
My question is: whether it would be possible to accomplish the above tasks in solely in Mavlink, or would it be better to use the ROS-Mavlink bridge.
If the latter, then which is easier to get started with, the ROS2 bridge, or ROS1. I am familar with both ROS2 and ROS1, but I understand that the implementation with PX4 and Mavlink for these two are quite different depending on the version
I read through the documentation for both, but any advice is appreciated,
Thanks
