Hello Folks.
I have a quad sitter VTOL, with a 5th pusher back motor for FW. Just to be clear,
(A) 4 motors for lift
(B) 5th motor for FW
They are all in the same plane. The UAV also has ailerons. None of the motor have tilt.
I want to understand as what airframe should I select it on px4 qgc setup, and how to configure the 5th motor. I want to be clear before I test the transition, lest I’ll break my UAV.
I want the 4 motors to be used for hover phases, and 5th motor for FW phase (in which 4 motors should turn off)
