Hi! Could someone help me analyze this log? We are experiencing a failsafe, but I’m not sure what the root cause might be.
I have do a extensive review. I have extract the csv from the ulog and I have reviewed all the tables on the timestamp the terminate trigger (second 732 aprox). We can observe a lack of data between second 732.4 and 734 in the following tables:
vehicle_gps_position_0
| timestamp | timestamp_sample | time_utc_usec | device_id | lat | lon | alt | alt_ellipsoid | s_variance_m_s | c_variance_rad | eph | epv | hdop | vdop | noise_per_ms | jamming_indicator | vel_m_s | vel_n_m_s | vel_e_m_s | vel_d_m_s | cog_rad | timestamp_time_relative | heading | heading_offset | heading_accuracy | rtcm_injection_rate | automatic_gain_control | fix_type | jamming_state | spoofing_state | vel_ned_valid | satellites_used | selected_rtcm_instance |
| 732223609 | 0 | 1756730244600000 | 8748035 | 432380268 | -19741499 | 164240 | 213861 | 0.004096985 | 0.28634223 | 0.013999288 | 0.0109998835 | 0.5800781 | 0.8598633 | 0 | 0 | 0.12435434 | -0.112 | 0.042000003 | 0.034 | 2.782822 | 0 | nan | nan | nan | 0 | 0 | 6 | 0 | 0 | 1 | 32 | 0 |
| 732414590 | 0 | 1756730244800000 | 8748035 | 432380266 | -19741497 | 164240 | 213861 | 0.0043563843 | 0.33151084 | 0.013999288 | 0.012000201 | 0.5800781 | 0.8598633 | 0 | 0 | 0.12243366 | -0.105000004 | 0.046000004 | 0.043 | 2.7286828 | 0 | nan | nan | nan | 0 | 0 | 6 | 0 | 0 | 1 | 32 | 0 |
| 734019320 | 0 | 1756730246400000 | 8748035 | 432380259 | -19741478 | 164130 | 213751 | 0.009216309 | 0.17370577 | 0.013999288 | 0.01000083 | 0.5800781 | 0.8598633 | 0 | 0 | 0.67360675 | 0.19600001 | 0.12100001 | 0.633 | 0.55307704 | 0 | nan | nan | nan | 0 | 0 | 6 | 0 | 0 | 1 | 32 | 0 |
estimator_gps_status_0
| timestamp | timestamp_sample | position_drift_rate_horizontal_m_s | position_drift_rate_vertical_m_s | filtered_horizontal_speed_m_s | checks_passed | check_fail_gps_fix | check_fail_min_sat_count | check_fail_max_pdop | check_fail_max_horz_err | check_fail_max_vert_err | check_fail_max_spd_err | check_fail_max_horz_drift | check_fail_max_vert_drift | check_fail_max_horz_spd_err | check_fail_max_vert_spd_err |
| 731701513 | 731522872 | nan | nan | nan | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| 732479021 | 732299607 | nan | nan | nan | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| 734083625 | 733904337 | nan | nan | nan | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
estimator_gps_status_1:
| 731481531 | 731294432 | nan | nan | nan | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| 732481793 | 732299200 | nan | nan | nan | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| 734097281 | 733903975 | nan | nan | nan | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
estimator_gps_status_2
| 731482641 | 731294570 | nan | nan | nan | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| 732479764 | 732299340 | nan | nan | nan | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| 734086189 | 733904070 | nan | nan | nan | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
on sensor_gps we have data:
| 731409820 | 0 | 1756730219800000 | 8748035 | 432379983 | -19742149 | 159560 | 209181 | 0.012992859 | 1624.1072 | 0.013999288 | 0.01000083 | 0.5698242 | 0.8598633 | 0 | 0 | 0.028142495 | 0.002 | 0.002 | 0.028 | 0.7853982 | 0 | nan | nan | nan | 0 | 0 | 6 | 0 | 0 | 1 | 32 | 0 |
| 732414590 | 0 | 1756730220800000 | 8748035 | 432379983 | -19742149 | 159570 | 209191 | 0.005329132 | 2.3695562 | 0.013999288 | 0.01000083 | 0.5698242 | 0.8598633 | 0 | 0 | 0.049739324 | 0.032 | -0.035 | -0.015000001 | -0.8301444 | 0 | nan | nan | nan | 0 | 0 | 6 | 0 | 0 | 1 | 32 | 0 |
| 733419523 | 0 | 1756730221800000 | 8748035 | 432379995 | -19742161 | 160520 | 210141 | 0.013221741 | 0.2916324 | 0.013999288 | 0.0109998835 | 0.5698242 | 0.8598633 | 0 | 0 | 1.4803926 | 0.20400001 | 0.061000004 | -1.465 | 0.29055712 | 0 | nan | nan | nan | 0 | 0 | 6 | 0 | 0 | 1 | 32 | 0 |
estimator_innovations:
| timestamp | timestamp_sample | gps_hvel[0] | gps_hvel[1] | gps_vvel | gps_hpos[0] | gps_hpos[1] | gps_vpos | ev_hvel[0] | ev_hvel[1] | ev_vvel | ev_hpos[0] | ev_hpos[1] | ev_vpos | rng_vpos | baro_vpos | aux_hvel[0] | aux_hvel[1] | aux_vvel | flow[0] | flow[1] | terr_flow[0] | terr_flow[1] | heading | mag_field[0] | mag_field[1] | mag_field[2] | gravity[0] | gravity[1] | gravity[2] | drag[0] | drag[1] | airspeed | beta | hagl | hagl_rate |
| 732199754 | 732029648 | -0.012723044 | -0.003446214 | -0.020076772 | 0.006489992 | 0.0031814575 | -0.007370949 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0.13182116 | 0 | 0 | nan | 0 | 0 | 0 | 0 | 0 | -0.22372743 | 0.49772236 | -0.32996523 | -0.5582536 | 0.19394527 | -0.009353897 | 0 | 0 | 0 | 0 | 0 | 0 |
| 732697905 | 732528014 | -0.009713165 | 0.019469969 | -0.024993958 | 0.013143063 | -0.0047597885 | -0.008559227 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | -0.09359217 | 0 | 0 | nan | 0 | 0 | 0 | 0 | 0 | -0.21780257 | 0.46236062 | -0.3248655 | 0.014335255 | -0.011641783 | 4.1404975E-05 | 0 | 0 | 0 | 0 | 0 | 0 |
| 733196362 | 733026489 | -0.009713165 | 0.019469969 | -0.024993958 | 0.013143063 | -0.0047597885 | -0.008559227 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | nan | 0 | 0 | 0 | 0 | 0 | -0.21780257 | 0.46236062 | -0.3248655 | -0.4263883 | 0.31041643 | -0.014648585 | 0 | 0 | 0 | 0 | 0 | 0 |
| 733694569 | 733524648 | -0.009713165 | 0.019469969 | -0.024993958 | 0.013143063 | -0.0047597885 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | nan | 0 | 0 | 0 | 0 | 0 | -0.21780257 | 0.46236062 | -0.3248655 | 0.21225813 | 0.37863955 | -0.009634689 | 0 | 0 | 0 | 0 | 0 | 0 |
During the timestamp the estimator innovations are static, and I suppose the EKF2 trigger the flag of attitude invalid and the drone go from OFFBOARD to TERMINATE mode.
- if GPS data are not valid, why EKF2 doesn’t take into account the IMU data?
- How I can to minimize this kind of issue?
