Quad plane: Sudden Drop in Airspeed & then It becomes normal
We did a long flight for a distance of a Quadplane with a wingspan of 3 m. It was flying at 20-22 m/s as programmed but after an hr its airspeed started giving reading of 14-15 m/s and after a while it became normal.
This again repeated a few times in the flight but with variable frequency. We changed airspeed sensor and did another flight but again observed similar behaviour.
Queries:
1- Why this happening & whats the fix?
2- Why the lower value is 14-15m/s and not below?
3-WHy changing Airspeed sensor have not fixed the issue?
Datalog is in the attachment.
Datalog
did you fix it ? i have same problem
Hi there.
Please share your logs using this tool: https://review.px4.io/
Did you change any settings during the flight?
Sounds like an airspeed sensor failure to me, but I need the log to confirm. What kind of airspeed sensor do you use?
