Hello Everyone,
I am using snapdragon FC and followed all the instruction for linux toolchain installation and building the 1st code given in px4 developer guide now i am trying it connect it with QGC but QGC not detecting it.
Thanks
Hello Everyone,
Thanks
What error do you get? Which version of QGroundControl are you using? Can you verify that your computer/device running QGroundControl is connected to the Snapdragon Flight’s access point? (See access point mode under WiFi settings on this page http://dev.px4.io/advanced-snapdragon.html). If that still does not help, please send the mini-dm and console outputs using the steps described here under Snapdragon DSP Console on the page http://dev.px4.io/advanced-system-console.html).
Thanks for the reply
When i am connecting my FC to QGC it does not show any error its not detecting it , i am using the latest daily build of QGC on Ubuntu 14.04
As i am working on a desktop so i can access the option (there is no file names with hostapd.conf in etc as mention in the link)
On the 2nd link i ran the command
cd /home/linaro
./px4 px4.config in adb shell window but there is no px4 folder/executable
I tried to build the code again but while running the command
make eagle_default i found this make errors
anuj.gupta@CPU-291U:~/src/Firmware$ make eagle_default
PX4 CONFIG: /home/anuj.gupta/src/Firmware/build_posix_eagle_default
[ 1%] [ 1%] Built target git_gencpp
Built target git_genmsg
[ 4%] Built target df_driver_framework
[ 4%] Built target prebuild_targets
[ 4%] [ 5%] [ 6%] Built target git_mavlink
Built target git_uavcan
Built target git_matrix
[ 6%] Built target generate_px4muorb_stubs
[ 7%] [ 7%] Built target git_ecl
Built target git_jmavsim
[ 7%] Built target git_gazebo
[ 7%] Built target mixer_gen
[ 8%] Built target xml_gen
[ 38%] Built target msg_gen
[ 39%] Built target generate_topic_listener
[ 39%] Built target platforms__common
[ 39%] [ 39%] Built target drivers__rgbled
Built target drivers__pwm_out_sim
[ 40%] [ 40%] Built target drivers__boards__sitl
Built target drivers__blinkm
[ 42%] Built target drivers__device
[ 43%] Built target drivers__qshell__posix
[ 44%] [ 45%] Built target drivers__led
[ 45%] Built target systemcmds__param
Built target systemcmds__mixer
[ 46%] Built target systemcmds__ver
[ 46%] Built target systemcmds__topic_listener
[ 46%] Built target modules__attitude_estimator_q
[ 47%] Built target modules__position_estimator_inav
[ 52%] Built target modules__mavlink
[ 53%] [ 53%] Built target modules__mc_pos_control
Built target modules__ekf2
[ 54%] Built target modules__mc_att_control
[ 57%] Built target modules__local_position_estimator
[ 57%] Built target modules__param
[ 59%] [ 60%] Built target modules__sensors
Built target modules__systemlib__mixer
[ 63%] Built target modules__uORB
[ 64%] Built target modules__sdlog2
[ 64%] Built target modules__dataman
[ 65%] Built target modules__muorb__krait
[ 69%] Built target modules__commander
[ 70%] [ 75%] Built target modules__simulator
Built target modules__navigator
[ 76%] Built target lib__controllib
[ 77%] Built target lib__mathlib
[ 77%] [ 77%] [ 77%] Built target lib__mathlib__math__filter
Built target lib__conversion
Built target lib__geo
[ 77%] [ 78%] Built target lib__geo_lookup
Built target lib__runway_takeoff
[ 78%] Built target lib__terrain_estimation
[ 78%] [ 85%] Built target lib__tailsitter_recovery
Built target lib__ecl
[ 88%] Built target platforms__posix__px4_layer
[ 88%] Built target lib__DriverFramework__framework
[ 88%] Built target modules__logger
[ 94%] Built target modules__systemlib
[ 98%] Built target platforms__posix__work_queue
Linking CXX executable px4
/home/anuj.gupta/Qualcomm/Hexagon_SDK/3.0/gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabihf_linux/bin/…/lib/gcc/arm-linux-gnueabihf/4.9.3/…/…/…/…/arm-linux-gnueabihf/bin/ld: cannot find crt1.o: No such file or directory
/home/anuj.gupta/Qualcomm/Hexagon_SDK/3.0/gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabihf_linux/bin/…/lib/gcc/arm-linux-gnueabihf/4.9.3/…/…/…/…/arm-linux-gnueabihf/bin/ld: cannot find crti.o: No such file or directory
/home/anuj.gupta/Qualcomm/Hexagon_SDK/3.0/gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabihf_linux/bin/…/lib/gcc/arm-linux-gnueabihf/4.9.3/…/…/…/…/arm-linux-gnueabihf/bin/ld: cannot find -lpthread
/home/anuj.gupta/Qualcomm/Hexagon_SDK/3.0/gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabihf_linux/bin/…/lib/gcc/arm-linux-gnueabihf/4.9.3/…/…/…/…/arm-linux-gnueabihf/bin/ld: cannot find -lrt
collect2: error: ld returned 1 exit status
make[3]: *** [src/firmware/posix/px4] Error 1
make[2]: *** [src/firmware/posix/CMakeFiles/px4.dir/all] Error 2
make[1]: *** [all] Error 2
make: *** [posix_eagle_default] Error 2
Hi
Sorry for the late reply i was stuck with makefile error to build the code
QGC still doesnot detect the Snapdragon FC
mini-dm output is
anuj@anuj-vm:~/Qualcomm/Hexagon_SDK/3.0/tools/debug/mini-dm/Linux_Debug$ ./mini-dm
Running mini-dm version: 3.0
Device found with Product ID 0x9025. Continuing…
mini-dm is waiting for a DMSS connection…
DMSS is connected. Running mini-dm…
[08500/00] 02:33.700 HAP:16415:In dspal_entry 0222 main.cpp
[08500/00] 02:33.700 HAP:16415:92813238 WorkMgr already initialized 0063 WorkMgr.cpp
[08500/02] 02:33.710 HAP:28713:Batch transfer failed: 0x110000c8 0524 i2c.c
[08500/00] 02:33.710 HAP:28713:92823368 error: read register reports a read of -1 bytes, but attempted to set 1 bytes 0133 I2CDevObj.cpp
[08500/00] 02:33.710 HAP:28713:92823416 error: unable to communicate with the hmc5883 mag sensor 0086 HMC5883.cpp
[08500/00] 02:33.710 HAP:28713:92823450 error: mag sensor initialization failed, sensor read thread not started 0155 HMC5883.cpp
[08500/03] 02:33.710 HAP:28713:HMC5883 start fail: -5 0165 df_hmc5883_wrapper.cpp
[08500/02] 02:33.713 HAP:28713:Batch transfer failed: 0x110000c8 0524 i2c.c
[08500/00] 02:33.713 HAP:28713:92827381 error: read register reports a read of -1 bytes, but attempted to set 1 bytes 0133 I2CDevObj.cpp
[08500/00] 02:33.715 HAP:28713:92827427 error: unable to communicate with the hmc5883 mag sensor 0086 HMC5883.cpp
[08500/00] 02:33.715 HAP:28713:92827461 error: mag sensor initialization failed, sensor read thread not started 0155 HMC5883.cpp
[08500/03] 02:33.715 HAP:28713:HMC5883 start fail: -5 0165 df_hmc5883_wrapper.cpp
[08500/02] 02:33.718 HAP:28713:Batch transfer failed: 0x110000c8 0524 i2c.c
[08500/00] 02:33.718 HAP:28713:92831499 error: read register reports a read of -1 bytes, but attempted to set 1 bytes 0133 I2CDevObj.cpp
[08500/00] 02:33.718 HAP:28713:92831541 error: unable to communicate with the hmc5883 mag sensor 0086 HMC5883.cpp
[08500/00] 02:33.718 HAP:28713:92831577 error: mag sensor initialization failed, sensor read thread not started 0155 HMC5883.cpp
[08500/03] 02:33.718 HAP:28713:HMC5883 start fail: -5 0165 df_hmc5883_wrapper.cpp
[08500/02] 02:33.722 HAP:28713:Batch transfer failed: 0x110000c8 0524 i2c.c
[08500/00] 02:33.722 HAP:28713:92835739 error: read register reports a read of -1 bytes, but attempted to set 1 bytes 0133 I2CDevObj.cpp
[08500/00] 02:33.722 HAP:28713:92835784 error: unable to communicate with the hmc5883 mag sensor 0086 HMC5883.cpp
[08500/00] 02:33.722 HAP:28713:92835821 error: mag sensor initialization failed, sensor read thread not started 0155 HMC5883.cpp
[08500/03] 02:33.722 HAP:28713:HMC5883 start fail: -5 0165 df_hmc5883_wrapper.cpp
[08500/02] 02:33.730 HAP:28713:Batch transfer failed: 0x110000c8 0524 i2c.c
[08500/00] 02:33.730 HAP:28713:92843155 error: read register reports a read of -1 bytes, but attempted to set 1 bytes 0133 I2CDevObj.cpp
[08500/00] 02:33.730 HAP:28713:92843199 error: unable to communicate with the hmc5883 mag sensor 0086 HMC5883.cpp
[08500/00] 02:33.730 HAP:28713:92843237 error: mag sensor initialization failed, sensor read thread not started 0155 HMC5883.cpp
[08500/03] 02:33.730 HAP:28713:HMC5883 start fail: -5 0165 df_hmc5883_wrapper.cpp
[08500/02] 02:33.733 HAP:28713:Batch transfer failed: 0x110000c8 0524 i2c.c
[08500/00] 02:33.733 HAP:28713:92847009 error: read register reports a read of -1 bytes, but attempted to set 1 bytes 0133 I2CDevObj.cpp
[08500/00] 02:33.733 HAP:28713:92847052 error: unable to communicate with the hmc5883 mag sensor 0086 HMC5883.cpp
[08500/00] 02:33.733 HAP:28713:92847086 error: mag sensor initialization failed, sensor read thread not started 0155 HMC5883.cpp
[08500/03] 02:33.733 HAP:28713:HMC5883 start fail: -5 0165 df_hmc5883_wrapper.cpp
[08500/02] 02:33.738 HAP:28713:Batch transfer failed: 0x110000c8 0524 i2c.c
[08500/00] 02:33.738 HAP:28713:92851850 error: read register reports a read of -1 bytes, but attempted to set 1 bytes 0133 I2CDevObj.cpp
[08500/00] 02:33.738 HAP:28713:92851893 error: unable to communicate with the hmc5883 mag sensor 0086 HMC5883.cpp
[08500/00] 02:33.738 HAP:28713:92851931 error: mag sensor initialization failed, sensor read thread not started 0155 HMC5883.cpp
[08500/03] 02:33.738 HAP:28713:HMC5883 start fail: -5 0165 df_hmc5883_wrapper.cpp
[08500/00] 02:33.741 HAP:16415:attempting to open the ADSP command file: /dev/fs/px4.config 0186 main.cpp
[08500/02] 02:33.742 HAP:28713:Batch transfer failed: 0x110000c8 0524 i2c.c
[08500/00] 02:33.742 HAP:28713:92855681 error: read register reports a read of -1 bytes, but attempted to set 1 bytes 0133 I2CDevObj.cpp
[08500/00] 02:33.742 HAP:28713:92855721 error: unable to communicate with the hmc5883 mag sensor 0086 HMC5883.cpp
[08500/00] 02:33.742 HAP:28713:92855758 error: mag sensor initialization failed, sensor read thread not started 0155 HMC5883.cpp
[08500/03] 02:33.742 HAP:28713:HMC5883 start fail: -5 0165 df_hmc5883_wrapper.cpp
[08500/00] 02:33.745 HAP:16415:reading commands from /dev/fs/px4.config 0193 main.cpp
[08500/02] 02:33.746 HAP:16415:already loaded 0067 uORBMain.cpp
[08500/00] 02:33.746 HAP:16415:already running 0081 qshell_start_qurt.cpp
[08500/02] 02:33.752 HAP:16415:Sleeping for 1, 1000000 0118 apps.h
[08500/02] 02:34.752 HAP:16415:GPS 1 already started 0979 gps.cpp
[08500/02] 02:34.758 HAP:16415:Batch transfer failed: 0x110000c8 0524 i2c.c
[08500/00] 02:34.758 HAP:16415:93871537 error: read register reports a read of -1 bytes, but attempted to set 1 bytes 0133 I2CDevObj.cpp
[08500/00] 02:34.758 HAP:16415:93871580 error: unable to communicate with the hmc5883 mag sensor 0086 HMC5883.cpp
[08500/00] 02:34.758 HAP:16415:93871617 error: mag sensor initialization failed, sensor read thread not started 0155 HMC5883.cpp
[08500/03] 02:34.758 HAP:16415:HMC5883 start fail: -5 0165 df_hmc5883_wrapper.cpp
[08500/03] 02:34.758 HAP:16415:DfHmc9250Wrapper start failed 0347 df_hmc5883_wrapper.cpp
[08500/03] 02:34.806 HAP:57:MESSED UP: worker = 0 0175 hrt_thread.c
[08500/00] 02:34.858 HAP:16415:93972276 Reset MPU9250 0089 MPU9250.cpp
[08500/00] 02:34.865 HAP:30:93977712 FIFO corrupt, temp difference: 15.279778, last temp: 49.138504, current temp: 33.858727 0526 MPU9250.cpp
[08500/00] 02:34.865 HAP:30:93978594 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.866 HAP:60:93979615 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.867 HAP:30:93980606 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.868 HAP:60:93981612 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.870 HAP:30:93983220 IMU temperature initialized to: 35.000000 0516 MPU9250.cpp
[08500/00] 02:34.870 HAP:30:93983277 FIFO corrupt, temp difference: 33.329639, last temp: 35.000000, current temp: 1.670361 0526 MPU9250.cpp
[08500/00] 02:34.871 HAP:60:93984615 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.872 HAP:30:93985637 IMU temperature initialized to: 35.000000 0516 MPU9250.cpp
[08500/00] 02:34.872 HAP:30:93985686 FIFO corrupt, temp difference: 33.329639, last temp: 35.000000, current temp: 1.670361 0526 MPU9250.cpp
[08500/00] 02:34.873 HAP:30:93986491 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.875 HAP:60:93987615 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.875 HAP:30:93988602 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.876 HAP:60:93989610 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.877 HAP:30:93990602 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.878 HAP:60:93991620 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.880 HAP:30:93992409 IMU temperature initialized to: 35.000000 0516 MPU9250.cpp
[08500/00] 02:34.880 HAP:60:93993617 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.881 HAP:30:93994597 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.882 HAP:60:93995607 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.883 HAP:16415:93996532 wrong mag ID 64 (expected 72) 0281 MPU9250_mag.cpp
[08500/00] 02:34.883 HAP:16415:93996571 MPU9250 mag not detected. 0092 MPU9250_mag.cpp
[08500/00] 02:34.883 HAP:16415:93996599 mag initialization failed 1 tries 0202 MPU9250_mag.cpp
[08500/00] 02:34.883 HAP:30:93996615 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.885 HAP:60:93997612 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.885 HAP:30:93998566 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.886 HAP:60:93999604 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.887 HAP:30:94000603 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.888 HAP:60:94001612 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.890 HAP:30:94002624 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.890 HAP:60:94003606 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.891 HAP:30:94004612 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.892 HAP:60:94005607 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.893 HAP:30:94006613 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.895 HAP:60:94007613 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.896 HAP:60:94009610 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.897 HAP:30:94010605 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.898 HAP:60:94011608 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.900 HAP:30:94012674 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.900 HAP:60:94013608 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.901 HAP:30:94014603 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.902 HAP:60:94015621 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.903 HAP:30:94016447 FIFO corrupt, temp difference: 4.963989, last temp: 35.000000, current temp: 39.963989 0526 MPU9250.cpp
[08500/00] 02:34.905 HAP:16415:94017468 wrong mag ID 64 (expected 72) 0281 MPU9250_mag.cpp
[08500/00] 02:34.905 HAP:16415:94017503 MPU9250 mag not detected. 0092 MPU9250_mag.cpp
[08500/00] 02:34.905 HAP:16415:94017531 mag initialization failed 2 tries 0202 MPU9250_mag.cpp
[08500/00] 02:34.905 HAP:30:94017560 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.905 HAP:60:94018570 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.906 HAP:30:94019607 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.907 HAP:60:94020601 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.908 HAP:30:94021611 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.910 HAP:60:94022620 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.910 HAP:30:94023611 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.911 HAP:60:94024607 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.912 HAP:30:94025615 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.913 HAP:60:94026609 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.915 HAP:30:94027610 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.915 HAP:60:94028602 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.916 HAP:30:94029655 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.917 HAP:60:94030595 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.918 HAP:30:94031609 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.920 HAP:60:94032620 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.920 HAP:30:94033606 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.921 HAP:60:94034606 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.922 HAP:30:94035686 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.923 HAP:60:94036601 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.925 HAP:30:94037608 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.926 HAP:30:94039411 IMU temperature initialized to: 35.000000 0516 MPU9250.cpp
[08500/00] 02:34.927 HAP:16415:94040619 set_mag_reg_verified failed for reg 50. 10!=2 0329 MPU9250_mag.cpp
[08500/00] 02:34.928 HAP:30:94041633 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.930 HAP:60:94042615 FIFO overflow 0397 MPU9250.cpp
[08500/00] 02:34.930 HAP:30:94043607 FIFO overflow 0397 MPU9250.cpp
[08500/02] 02:35.723 mmpm_register: MMPM client for USM ADSP core 12 0117 UltrasoundStreamMgr_Mmpm.cpp
[08500/02] 02:35.725 ADSP License DB: License validation function with id 164678 stored. 0280 adsp_license_db.cpp
[08500/02] 02:35.725 AvsCoreSvc: StartSvcHandler Enter 0518 AdspCoreSvc.cpp
[08500/02] 02:35.725 AdspCoreSvc: Started successfully 0534 AdspCoreSvc.cpp
[08500/02] 02:35.728 loading BLSP configuration 0217 blsp_config.c
[08500/02] 02:36.016 HAP:110:cannot find /oemconfig.so 0141 load.c
[08500/03] 02:36.016 HAP:4211::error: -1: 0 == dynconfig_init(&conf, “security”) 0696 sigverify.c
[08500/02] 02:36.016 HAP:80:cannot find /voiceproc_tx.so 0141 load.c
[08500/02] 02:36.017 HAP:80:cannot find /voiceproc_rx.so 0141 load.c
[08500/02] 02:36.017 HAP:159:unable to open the specified file path 0167 file.c
[08500/04] 02:36.017 failed to open /usr/share/data/adsp/blsp.config 0233 blsp_config.c
[08500/00] 02:36.017 loading the blsp config file failed, loading the default config 0261 main.c
[08500/02] 02:36.017 Loaded default UART-BAM mapping 0036 blsp_config.c
[08500/02] 02:36.017 UART tty-1: BAM-9 0044 blsp_config.c
[08500/02] 02:36.017 UART tty-2: BAM-6 0044 blsp_config.c
[08500/02] 02:36.017 UART tty-3: BAM-8 0044 blsp_config.c
[08500/02] 02:36.017 UART tty-4: BAM-2 0044 blsp_config.c
[08500/02] 02:36.017 UART tty-5: BAM N/A 0049 blsp_config.c
[08500/02] 02:36.017 UART tty-6: BAM N/A 0049 blsp_config.c
thanks
