Hi All,
Getting the following error after building QGC in Qt creator
After building the source repo, following which I am trying to run the application.
Following is Application output
20:12:19: Starting D:\Projects\UAV\build-qgroundcontrol-Desktop_Qt_5_12_6_MSVC2017_64bit-Release\staging\QGroundControl.exe …
20:12:24: The program has unexpectedly finished.
20:12:24: The process was ended forcefully.
20:12:25: D:/Projects/UAV/build-qgroundcontrol-Desktop_Qt_5_12_6_MSVC2017_64bit-Release/staging/QGroundControl.exe crashed.
I am unable to debug as well
Is there any issue with the build. Any need for changes in qgroundcontrol.pro file.
Really appreciate if anyone can help me get it up and running on my local system.
