I am running PX4 as SITL and I am unable to run any python code because of a system health failure. But how could there be a system failure when in SITL?
Please share the full output from your terminal in a text file.
Greetings,
Thank you for responding to me.
Unfortunately, I did not save off the output (I know, I should know better).
I wrestled with this for 6-7 hours.
In the past, restarting QGC or PX4 worked.
I re-started both QGC and PX4 several times.
I tried disconnecting the QGC from the vehicle after killing PX4, and that did not work
I am not sure why it suddenly started working near the end of the work day.
My concern is, if our team goes this route, will other developers on the team lose a day of work due to this?
The errors that I saw are outlined below.
â something about setting pre-flight value(s)
â system health status was bad
â strong magnetic interference
Map Positioning â Another question that I had
Also, when creating a mission, can I dynamically move the QGC map to the correct part of the world?
It seems to default to Germany.
I had to create a .sdf file and kick off PX4 by setting the PX4_GZ_WORLD variable to my world file.
Is there a better way to position the world for SITL/simulation development?
Without the exact details of the error it is going to be impossible to help. I would suggest asking in the simulation channel on PX4 Discord for faster responses. Thereâs also a discussion there about adding support for changing the world coordinates.
And here is the PX4 output
px4 starting.
INFO [px4] startup script: /bin/sh etc/init.d-posix/rcS 0
INFO [init] found model autostart file as SYS_AUTOSTART=8011
INFO [param] selected parameter default file parameters.bson
INFO [param] importing from 'parameters.bson'
INFO [parameters] BSON document size 536 bytes, decoded 536 bytes (INT32:17, FLOAT:9)
INFO [param] selected parameter backup file parameters_backup.bson
INFO [dataman] data manager file './dataman' size is 1208528 bytes
INFO [init] Gazebo simulator
INFO [init] Starting gazebo with world: /home/afoster/PX4-Autopilot/Tools/simulation/gz/worlds/ulster.sdf
INFO [init] Waiting for Gazebo world...
INFO [init] Gazebo world is ready
INFO [init] Spawning model
INFO [gz_bridge] world: ulster, model: omnicopter_0
INFO [lockstep_scheduler] setting initial absolute time to 4196000 us
INFO [commander] LED: open /dev/led0 failed (22)
WARN [health_and_arming_checks] Preflight Fail: ekf2 missing data
INFO [tone_alarm] home set
INFO [uxrce_dds_client] init UDP agent IP:127.0.0.1, port:8888
INFO [mavlink] mode: Normal, data rate: 4000000 B/s on udp port 18570 remote port 14550
INFO [mavlink] mode: Onboard, data rate: 4000 B/s on udp port 14280 remote port 14030
INFO [mavlink] mode: Gimbal, data rate: 400000 B/s on udp port 13030 remote port 13280
INFO [logger] [logger] ./log/2025-03-31/16_38_58.ulg
INFO [logger] Opened full log file: ./log/2025-03-31/16_38_58.ulg
INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
pxh> INFO [mavlink] partner IP: 127.0.0.1
ERROR [mavlink] vehicle_command_ack lost, generation 1 -> 24
ERROR [mavlink] vehicle_command_ack lost, generation 2 -> 24
WARN [health_and_arming_checks] Preflight Fail: Strong magnetic interference
Looks like youâre using a custom world. If you have plugins defined in your world file you need to remove them and use the server.config. Likely missing the magnetometer plugin.
My custom world is just the default.sdf with the name and location changed
And, is there a way to move the map and home position without creating a custom world?
Does the location in the world affect which plugins are needed?
I just looked at the server.config and it has the magnetometer plugin
This file is located in
~/PX4-Autopilot/src/modules/simulation/gz_bridge/server.config
on my system
Not yet, but it should be easy to add. See the discussion on discord here.
No it shouldnât
Does the sim work with the default world?
I re-ran the python code using the default world.
Then I ran on the cmd line the discord re-position cmd
The map moved to the right location, although it took a minute or so to do it.
And the status was ready to fly.
Is there a way to re-position the map dynamically in python code?
In any case, that may have gotten me past the not ready status.
I only say may have, because the status seems to be hit and miss sometimes.
But, that may be a workaround.
Time will tell.
This needs to happen in the startup script. We need a PR to change the world coordinates after the world is loaded but before the model is spawned. If you want to add that feature it would be welcomed.
What do you mean by a startup script?
I was running a python3 .py
is that incorrect?
The gz startup script is here
I think that you are telling me that it is not possible to move the map in python?
When I do the cmd
make px4_sitl gz_x500
gazebo starts up automatically.
I have been running the code below in a shell script that I created from another terminal to move the position.
gz service
-s /world/default/set_spherical_coordinates
âreqtype gz.msgs.SphericalCoordinates
âreptype gz.msgs.Boolean
âtimeout 2000
âreq âsurface_model: EARTH_WGS84, latitude_deg: $lat, longitude_deg: $lon, elevation: $altâ
When I do the cmd
Yes and this make command calls the startup script I linked above
Yes and I am suggesting you add that shell command to the startup script to set the location. Take a look at the startup script and you will see other gz commands for: spawning model, setting sim speed, camera follow, etc. I am suggesting that we implement env variables for a non-default lan/lon/alt in the same way that the other simulators allow this.
PX4_HOME_LAT
PX4_HOME_LON
PX4_HOME_ALT
AAH, that makes sense, thank you
If anyone is checking because of the original health error.
For me, that was happening because the map position was too far from the launch point.
