QGC not connected to pixhawk is normal, USB once connected to pixhawkQGC will crash,I uninstalled and tried to install many different versions of QGC, the same problem
Which OS is this? And also which version of QGC?
It looks like users are experiencing crashes with QGroundControl when connecting to Pixhawk via USB. This could be linked to version compatibility or OS-related issues. Troubleshooting by checking the software and hardware setup may help resolve this.
windows,QGC try 4.2.8…different virsion.I uninstalled and reinstalled different versions of QGC several times. Maybe soe internal driver software was not uninstalled completely during the process (for example, there is a driver called UAV driver that comes with QGC, but it will not uninstall itself when uninstalled). The reinstalled version is incompatible? As a result, when connecting the pixhawk via USB, QGC immediately freezes and becomes unresponsive.
windows,QGC try 4.2.8…different virsion.I uninstalled and reinstalled different versions of QGC several times. Maybe QGC internal driver software was not uninstalled completely during the process (for example, there is a driver called UAV driver that comes with QGC, but it will not uninstall itself when uninstalled). The reinstalled version is incompatible? As a result, when connecting the pixhawk via USB, QGC immediately freezes and becomes unresponsive.
