OS: Windows 10
QT Version: 5.15.2
I tried to compile with both qmake and cmake on QGC Qt Creator.
When I compiled it with qmake, the codes compiled correctly. But when I try to compile with cmake it gives an error.
linux operating system is running. I think it’s the bottom part.
if (WIN32) # append application icon resource for Windows set(QGC_RESOURCES ${QGC_RESOURCES} **${CMAKE_CURRENT_SOURCE_DIR}/windows/QGroundControl.rc)** endif()
Since there is no such path, it gives an error in the add_executable part. When switching to the win operating system, this part is opened.
${CMAKE_CURRENT_SOURCE_DIR}/windows/QGroundControl.rc) path should be fixed to ${CMAKE_CURRENT_SOURCE_DIR}/deploy/windows/QGroundControl.rc) so that cmake will run
Although it doesn’t work as well as the result of compiling with qmake, at least cmake works on compiling.
Can this situation be controlled?
