I get an error when I make a change in the CMakeLists.txt file in the QGroundControl software
Environment and versions I work with:
  • Windows 10
  • QT: 6.6.3
Problem: When I try to build the QGC application via cmake, it compiles the first time and runs the application. However, when I make a change on cmake, it gives an error. When I delete the build file and compile it again, it works this time.
error: unknown target 'all_qmllint'
07:07:35: The process "C:\Qt\Tools\CMake_64\bin\cmake.exe" exited with code 1.
Error while building/deploying project QGroundControl (kit: Desktop Qt 6.6.3 MSVC2019 64bit)
When executing step "Build"
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
C:/ems/qgroundcontrol/build/Desktop_Qt_6_6_3_MSVC2019_64bit-Release/_deps/exiv2-src/src/ZLIB_INCLUDE_DIR
   used as include directory in directory C:/ems/qgroundcontrol/build/Desktop_Qt_6_6_3_MSVC2019_64bit-Release/_deps/exiv2-src/src
CMake Warning (dev) in build/Desktop_Qt_6_6_3_MSVC2019_64bit-Release/_deps/geographiclib-src/src/CMakeLists.txt:
  Policy CMP0100 is not set: Let AUTOMOC and AUTOUIC process .hh files.  Run
  "cmake --help-policy CMP0100" for policy details.  Use the cmake_policy
  command to set the policy and suppress this warning.
  For compatibility, CMake is excluding the header file(s):
    "C:/ems/qgroundcontrol/build/Desktop_Qt_6_6_3_MSVC2019_64bit-Release/_deps/geographiclib-src/src/kissfft.hh"
  from processing by AUTOMOC and AUTOUIC.  If any of the files should be
  processed, set CMP0100 to NEW.  If any of the files should not be
  processed, explicitly exclude them by setting the source file property
  SKIP_AUTOGEN:
    set_property(SOURCE file.hh PROPERTY SKIP_AUTOGEN ON)
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Generating done (1.9s)
CMake Generate step failed.  Build files cannot be regenerated correctly.
ninja: error: rebuilding 'build.ninja': subcommand failed
FAILED: build.ninja
C:\Qt\Tools\CMake_64\bin\cmake.exe --regenerate-during-build -SC:\ems\qgroundcontrol -BC:\ems\qgroundcontrol\build\Desktop_Qt_6_6_3_MSVC2019_64bit-Release
11:21:30: The process "C:\Qt\Tools\CMake_64\bin\cmake.exe" exited with code 1.
  • I just added `message(“aaaa”)" to the cmake file
HI,
In the QGC installation guide Download and Install | QGC Guide (master), they provide an executable to install QGC application on WIndows. It does not require cmake or anything
My goal is to develop qgc so I’m trying to understand why I get this error on the windows side
