QGC Daily Builds network not available
When I open the application, the map does not load. When I open the console, I constantly get this error “network not available”. There is no problem with my internet connection. I need to use this version because I need to use custom mode. how do i solve this problem
Are you building QGC using container?
No, I’m not using any container. Should I use any container? If I need any container, how can I use it?
I have the same issue (qgc.qtlocationplugin.qgeomapreplyqgc: 1 “Network Not Available”) if I use the QGC Daily from https://github.com/mavlink/qgroundcontrol/releases/download/latest/QGroundControl-x86_64.AppImage under WSL (Windows Subsystem for Linux). If I run the same binary @ my Linux Ubuntu Laptop it works and maps can be displayed. The QGC v4.3.3 AppImage release works without issues under WSL. How to find out what’s different/missing?
