Hello everyone,
I tried the tutorial ‘https://dev.px4.io/en/simulation/ros_interface.html’. QGC could connect with the simulator when i tried ‘make posix_sitl_default gazebo’. But when I tried to use gazebo with ROS wrappers, I did ‘roslaunch px4 posix_sitl.launch’. The simulator can be started, but QGC can not communicate with the simulator. Has anyone meet this problem? How can i do to make QGC communicate with the simulator.
Thank you.
Hi, I’m having the same problem. Did you fix it? Also I can’t connect to the offboard computer when executing mavros
I am also investigating this same issue by swimming around google ocean…
