Python - fly to a waypoint given by GPS coordinates
Is there a MAVSDK-Python example code to fly to a waypoint given by GPS coordinates ?
Something like this ?
Yes, thanks a lot…
But this code makes the drone flying sideways not straight ahead, anyone have an idea to make the drone turn around and flight straight ahead ?
Like this image
You can change line 37. The last parameter of the goto_location() method is the yaw angle, in degrees. Or you can add a new line before that first rotates the UAV and then goto_location as line 37.
@fulano
Great, but is there an easy way to calculate the Yaw angle directly ?
I could do it using latitude_deg and longitude_deg from drone.telemetry.position()
Thanks all
async for position_info in drone.telemetry.position():
current_latitude = position_info.latitude_deg
current_longitude = position_info.longitude_deg
break
yaw_angle = math.degrees(math.atan((destination_longitude - current_longitude) / (destination_latitude - current_latitude)))
if destination_latitude < current_latitude:
yaw_angle += 180
