This surely has been asked before and I just cannot find it. I can’t be the first one.
How to check if a drone has reached a target position after issuing a goto_location command?
Right now, my solution is to regularly check the drone’s position and consider the waypoint done when the difference between actual and target position lies within a certain tolerance. It then waits a few seconds to let the drone settle itself at the new position and moves on.
import math
from mavsdk import System
TOLERANCE_DEG = 0.00005
TOLERANCE_M = 0.3
WAIT_FOR_TARGET = 2
uav = System()
lat = ...
lon = ...
alt = ...
yaw = ...
await uav.action.goto_location(lat, lon, alt, yaw)
last = 0
async for position in uav.telemetry.position():
curr = time.time()
if (curr - last >= 1):
last = curr
diff_lat = math.fabs(position.latitude_deg - lat) - TOLERANCE_DEG
diff_lon = math.fabs(position.longitude_deg - lon) - TOLERANCE_DEG
diff_alt = math.fabs(position.relative_altitude_m - alt) - TOLERANCE_M
if (diff_lat <= 0 and diff_lon <= 0 and diff_alt <= 0):
print("Reached target vincinity, wait another " + str(WAIT_FOR_TARGET) + " s")
asyncio.sleep(WAIT_FOR_TARGET)
print("Reached target position")
break
However, this feels a little hacky. This approach is based on a lot of estimates that may change with drone model or situation.
Is there a better solution to do this?
Thanks and best regards.
Hello, I had the same problem. I needed to execute some custom code when I reached a checkpoint of a mission. I implemented something similar to your approach because I don’t think there is a possibility to get a callback when the point is reached. For missions, you can get a callback when the drone leaves, but that is also not super helpful.
Here is my solution. It checks whether the distance in meter is lower than the acceptance distance:
val missionPlan = MissionPlan(flightPlan.checkpoints?.map {
Mission.MissionItem(
it.latitude,
it.longitude,
10f,
5f,
false,
0f,
0f,
Mission.MissionItem.CameraAction.TAKE_PHOTO,
5f,
0.0,
1f,
0f,
0f,
Mission.MissionItem.VehicleAction.NONE
} ?: emptyList())
drone?.mission?.uploadMission(missionPlan)?.blockingAwait()
drone?.mission?.setReturnToLaunchAfterMission(true)?.blockingAwait()
drone?.mission?.setCurrentMissionItem(0)?.blockingAwait()
drone?.mission?.startMission()?.blockingAwait()
var currentCheckpoint = missionPlan.missionItems[0]
var checkpointReached = false
drone?.mission?.missionProgress?.subscribe {
currentCheckpoint = missionPlan.missionItems[it.current]
drone?.telemetry?.position?.subscribe {
if (checkpointReached) {
return@subscribe
val distanceM = haversine(
currentCheckpoint.latitudeDeg,
currentCheckpoint.longitudeDeg,
it.latitudeDeg,
it.longitudeDeg
if (distanceM < 1) {
checkpointReached = true
println("Checkpoint reached!")
Distance function:
private fun haversine(lat1: Double, lon1: Double, lat2: Double, lon2: Double): Double {
val radiusEarth = 6371000
val dLat = Math.toRadians(lat2 - lat1)
val dLon = Math.toRadians(lon2 - lon1)
val originLat = Math.toRadians(lat1)
val destinationLat = Math.toRadians(lat2)
val a = sin(dLat / 2).pow(2) + sin(dLon / 2).pow(2) * cos(originLat) * cos(destinationLat)
val c = 2 * atan2(sqrt(a), sqrt(1 - a))
return radiusEarth * c
The same approach can be used for goto_location. Maybe this helps someone in the future.
