Dear all,
I am trying to use a motor model based mixer, I was able to load the new pre-computed mixing matrix (the one to be cast to the structure Rotor of the class MultirotorMixer) in the place of the nominal one corresponding to my drone configuration and I modified the function mix to correspond to the new mixing strategy (two steps: thrust distribution followed by the inverted motors model to find the corresponding throttle outputs), without overflowing the flash memory (which was quite challenging for me ^^).
Now when I flash this on my DroPix and reboot, the PX4IO does not like it at all.
The error log is below (looks pretty bad, it basically fails to update the PX4IO). I need some orientation to understand the causes of the problem and to start troubleshooting this mess… Thanks
px4io: check CRC failed: -22: Invalid argument
INFO default PWM output device
[PX4IO] using firmware from /etc/extras/px4io-v2.bin
[PX4IO] bad sync 0xff,0xff
[PX4IO] bad sync 0xff,0x7f
[PX4IO] bootloader not responding
[i] ERROR: PX4IO not found
[i] ERROR: PX4IO not found, disabling output
mavlink_if0: mode: 0, data rate: 80000 B/s on /dev/ttyS1 @ 921600B
adc init done
sensors: ERROR: no barometer found on /dev/baro0 (2)
ebgpio on I2C bus 1 at 0x38 (bus: 100 KHz, max: 100 KHz)
[i] MULTICOPTER
mixer: can’t open /dev/pwm_output0
mixer: failed to load mixer
[i] Error loading mixer: /etc/mixers/octo_cox.main.mix
