PX4 Sync / Q&A: Nov 20, 2024
Dronecode Calendar
Agenda
  • Announcements
  • Release Discussion
  • Q&A
Announcements
  • We added Ubuntu 24.04 Dev Env support. Currently, the development environment is supporting two lates Ubuntu LTS
Release Discussion
Bug report / Q&A
1- @SirNarfalot: Position mode accuracy seems to be low like in meters?
@Benja Opening an issue and log file will help to further investigate.
2- @Sayshara : Is there a way to keep the same init order for specific sensor IDs always to use simultaneous sensors?
@sfuhrer no support for multiple instances of the airspeed sensors in calibrations.
@bresch Always recommended to check the device ID in each boot to put the order as required
3- @Benja Any updates on PX4 msgs versioning? Already these two PRs are proposed:
PRs needing review
Merged PRs
